There's some oil in the airbox,
This is a new-to-me 1998 Cali EV with 13,xxx miles. I've been taking it apart and playing with it for the past couple of weeks. There's some oil in the airbox, and the oil drain totals exactly three quarts. (I didn't spill any [this time]). The book says three liters for an oil change (with filter).I ask because proper Moto Guzzi motorcycle oil refill amounts can sometimes be a mystery - regardless of what the dipstick shows.
That is too vague. How much is 'some'? Patrick HayesFremont CA
I always did 3L on my EV's and never had an issue. Same with Jan's Jackal. Many, many combined miles between these bikes.Dino or synthetic? John Henry
On my next oil change all my Gussies will get 3qts. Take 1qt and fill the filter, then use the remainder and 2 more quarts. Done.The EVT has been fine with 3ltr, but I will keep them all the same.I don't remember where I bought it, maybe MG. They have IIRR an unmarked dipstick with a round silver rod for the EV. Add your 3qts, run the bike, let settle and mark the level. Next time add 2qts and mark your low level.Tom
When you fill the filter what keeps it from draining out when you screw it on the sump?
Also use the obligatory Guzzi hose clamp. Makes me feel better.
The original poster sounds new to Guzzi and may not know of what you write. Patrick HayesFremont CA
No he snot new to Guzzi. Prolly knows about the hose klamp.John Henry
I use 3 qts. exactly, oil filter or no oil filter. Hose clamp:
Yep, me too, except I don't use UFIs or a hose clamp.
Customer supplied the filter, I normally use HiFloFiltro.
Customer supplied the filter, I normally use HiFloFiltro. Always use a hose clamp though, costs 95 cents and there is no downside to it's use.
