The light should come on when the key is on and the engine is not running. It comes on when the lead is grounded. Take a jumper from the engine (ground) and touch or clip it to the wire end that goes in the oil pressure switch. You don’t have to disconnect it if you can get to a bare spot where it is connected. If the light doesn’t come on, it’s probably a bulb
Glad it was only the sensor, in my case it was the oil pump.
I mean who knows, the pump could be bad too . But if I’ve put 200 miles on this thing already, so if that was the case the engine would be screwed with a capital S. God willing the light turns back off when the engine goes on 0.0MG cycle would take a bit too long for my tastes. Any thoughts on a diy cover using electrical tape? Not a budget situation obviously more ease of access. ----Update: I need new fork seals, so I will buy that cover as well from whoever I get the seals from. Hamlin is my first hit, would do Af1 after that but considering mg cycle has all of it I'll probably just use them.
