Pretty sure you guys are talking about offset in terms of steering geometry , not wheel offset . Dusty
Sopwith Camel if I remember rightly.Maurie.
No, The wheel was offset to the left as I recall. There may have been different rake and trail numbers but that is steering geometry in my dictionary.
OK Dusty, I see that race bikes are using more offset(adjustable triple clan end a bit more mps) to have less trail and vise versa. And yes, the rake(steering head angle) is only slightly adjusted by the fork height or rear suspension settings. I did forget that I had to adjust the old Kawasaki fork tubes for height along with axle settings to affect rake. Not remembering the 70's like I used to. Mike
Hmm , I simply can't find anything on this . Normally offset is defining the distance between the centerline of the forks and steering stem . Increasing that measurement increases trail adding stability. Any chance you might find the article , now I am curious . Dusty
it's in the workshop manual for the R1100S, page 48 I think
Kirby, your comment regarding P factor being soley due to the downgoing blade having greater angle of sttack is not true. It is a factor but not the only one. If that was the case then in straight and level flight thete would be no yaw present since both blades have the same AoA. Anoter cause is the spiralling slipstream over the fuselage striking the fin and rudder unevenly causing a yaw tendancy, but here's the reason that matters here. If you've flown a tailwheel a/c like Pawnee, Piper Cub etc. you'll notice that sn additional swing will be frlt as you are in the process of rotating onto the mains only, this is the rotating mass of the prop disc being pitched forward and gyroscopic precession taking place. Any good text book will tell you this, or Google it. The reason I touched on it was could there be a similar effect when the Guzzi or BM is pitched up or fown over a bump causing a corresponding tendancy to roll. Sorry about the dpelling errors, I csn't get the cursor to show on my little 'phone so can't go back to correct them. Huzo.
Ahh , the original rotarys. AND , there was the Megola motorcycle with the rotary engine fixed to the FRONT wheel . Dusty
FTFYOh, and I'm not about to argue with Mike about how an airplane works because, well.. he's right. :)He has more time on final than most pilots have total time.
Yeah look when your your right, and he's damn well right.
Yeah after all Oldie,fun is why we do it, isn't it ?
And by the way, I'll stick to Guzzi content, thanks for the nudge to get me totally on line, I'm afraid it's been a bit too long between drinks. A little tutorial hasn't done me any harm, thanks mate.
I found one mention of the K model BMW rear wheel being offset 5 mm to the right to offset it's weight bias to the right. Would make more sense than they set the welding jigs up wrong. Not seeing any way to adjust the rear of shaft drive bikes in any manual I have. I am a bit confused about the brake comments since Calipers and or Pistons must move the pads to contact the rotors. They are designed to do that compensating for where the rotors end up on a wheel and pad wear. If you don't move a wheel too much most brakes should be able function fine. But why would you want to move something from where it is designed to be in the first place? Mike
I don't know about the design principals behind it but I've found that the Cal series has a track offset of about ten to twenty mm. When I first discovered it, I thought it was damage or a defect on my bike but I could not adjust it out. I then found it on others but I don't know the reason for it.
Having said that, has anyone come up with a plausible answer based on some sound design principles ?
