Well , it kinda makes sense , although there is likely a different explanation . Could be a way to mess with people's heads Dusty
I have thought about it some more, and Dusty is just wrong. A 90 degree engine is not an L engine. Nor is it a V engine. It's actually a caret engine.After all, if you keep rotating the letter L or V, you wind up with an editor's caret mark. ^Moto Guzzi: The Way the Caret Was Meant to Be !
Haven't we already covered this, NOTHING is an L-twin unless the vertical cylinder's stroke is twice the horizontal's.
So the Douglass motorcycle company was wrong to call their 680 CC 90 degree twin an L twin then? Dusty
I'm not familiar with it, but if they had equal strokes, then yes...
Well there ya have it , those engineers were just wrong then . Dusty
So Ducati calls my V twin Monster engine a L....Damn, so one cylinder has a 2.6 inch stroke and the other a 5.2 inch stroke...? Man ,that 5.2 inch stroke at 8000 rpm has to have some serious piston speed...........
An engine that's slipped from memory because not many have experience of it is MV's 750cc across-the-frame four (..and I don't mean Cagiva's modern-day offering!). Designed half a century ago, and still unmatched for sheer machismo, this engine makes most modern powerplants look, sound and feel powder-puff. With gear-driven cams, proper open-bellmouth DellOrto carbs and open race pipes, it sounds like rolling thunder from idling to peak revs (..it's way more spine-chilling than even Ducatis with Termignonis). It has roller-bearings everywhere, it's got horizontally-split sandcast casings enabling easy removal of the crank, and an automotive-style distributor for easy timing checks. Completely free of vibration on the road; it needs no rubber-mounts whatever, anywhere ~ even the footpegs are plain turned steel and bolted directly to the frame. It makes power from idle to max revs (..it's quicker than a Mk1 Le Mans) and it has the kind of 'real world / on-the-road' flexibility you would hardly believe from a motor that brought MV Agusta 37 World Championship titles (..the race engine had magnesium casings, but was of the same design).No engine is more handsome, IMHO: it looks like it's been carved from rock ~ and it can be stripped down at the roadside with barely any more than two spanners and a screwdriver! It has to be a contender for 'best ever'.This audio hardly does it justice. Turn up your speakers: https://www.youtube.com/watch?v=fImkF4zafXQ
Well now you've gone and done it haven't you................ .....that's it, we have a winnerThread Closed
