An engine that's slipped from memory because not many have experience of it is MV's 750cc across-the-frame four (..and I don't mean Cagiva's modern-day offering!). Designed half a century ago, and still unmatched for sheer machismo, this engine makes most modern powerplants look, sound and feel powder-puff. With gear-driven cams, proper open-bellmouth DellOrto carbs and open race pipes, it sounds like rolling thunder from idling to peak revs (..it's way more spine-chilling than even Ducatis with Termignonis). It has roller-bearings everywhere, it's got horizontally-split sandcast casings enabling easy removal of the crank, and an automotive-style distributor for easy timing checks. Completely free of vibration on the road; it needs no rubber-mounts whatever, anywhere ~ even the footpegs are plain turned steel and bolted directly to the frame. It makes power from idle to max revs (..it's quicker than a Mk1 Le Mans) and it has the kind of 'real world / on-the-road' flexibility you would hardly believe from a motor that brought MV Agusta 37 World Championship titles (..the race engine had magnesium casings, but was of the same design).No engine is more handsome, IMHO: it looks like it's been carved from rock ~ and it can be stripped down at the roadside with barely any more than two spanners and a screwdriver! It has to be a contender for 'best ever'.This audio hardly does it justice. Turn up your speakers: https://www.youtube.com/watch?v=fImkF4zafXQ
The round case bevel twin is definitely one of the best looking engines ever made!
My favorite MC engine I've owned so far is the 805cc V-twin on my Suzuki `91 VX800. It has very linear power....no vibration issues.....bike handles good with superbike handlebar(not original HB).....sound isn't bad......low maintenance....127 mph top speed.....most trouble free bike I've ever owned(sorry Moto Guzzi).
The specs say top speed just short of 117 , which seems more likely for a 520 lb motorbike with a claimed 62 HP . Dusty
However attractive the Agusta 750/850 were, I can�t help remembering the write- up from a French Canadian journo of that era, went something like this: � even though I get along well with the importer and he has lend me his 750 America, it�s a fine motorcycle but can�t help thinking the weight of the machine spoils everything�
Yes, weight is the Achilles Heel of these MVs, and back in the day it mattered. Rumour has it that the Count didn't want privateers on MVs competing with the works bikes so added weight/shaft drive etc to discourage it. Today, it doesn't have to compete: its a classic for a Sunday run. My post wasn't about the bike though; it was about the engine. The engine's a real cracker, and way better (in all respects) than you'd imagine - or any contemporary figures suggest.Of more modern-day engines, I'd have to agree with someone else's suggestion: Honda's V-4. The 750cc (RC) engine will pull top gear from idle to 12,000rpm, and respond in an instant at any point in the rev-range. Nothing I've ridden matches it for real-world usability. Filled with drive-gears, roller-bearings, titanium rods & magnesium fittings, etc, it's a real jewel. Steve
..what put a downer on the MV was that in real life it is not much faster than a Guzzi 750 ambassador and the valve angles technology is hold hat.Read the comparison here. Both 14 second quarter miles, with real top speed of 115!http://www.yeoldecycleshoppe.com/roadtestlibrary/2016/11/26/1971-mv-750-four-road-test?rq=MV%20Agusta
'Cause its just so pretty
