611 is for the ECU performance and you think its not running correctly, this is likely to be more than a coincidence?
I’m with you my 16 V7II ran very similar to what you describe. Occasionally it would stall while warming up ,just as it went closed loop. A flat spot the size of Nebraska ! The dealer was of little to no help.Many suggested a new map & they are very likely correct. I didn’t feel an extra outlay of approximately $500 was prudent as it had under 1k Mi. & the drivability issue should be the Mfg’s responsibility.Against the opinion of many here & on other websites I tried a pair of O2 sensor signal modifiers, for which I was severely castigated!A huge improvement was noticed almost immediately. Now with over 12k Mi. So far so good . As I was informed this is a band aid approach . Mileage is around 50 mpg. Oil consumption is minimal , plugs look good , no pinging or other signs of poor running & head temps are pretty even .Sooo until get a cash windfall or easier access to a capable computer technician I’m sticking with what has worked OK so far. I don’t dought the benefit of custom mapping , its just not in my wheelhouse @ this moment.
Just an FYI, but I'm under the impression that a Bettle map is about $100, not $500.
It's not a III Dusty, it's a II.And you're wasting your breath.
Ahh , so probably a thrust washer issue . Look fellas , no doubt this is frustrating , but we have witnessed these issues resolved in a satisfactory fashion several times , yes it takes patience, we are after all dealing with a small Italian motorcycle maker , not Honda or the MoCo , who occasionally mess up also . My best suggestion , always listen to people who have vast experience with Moto Guzzi , or sell the bike and buy a Honda . More accurately , buy a Yamaha , they have the best reliability rating currently . Dusty
Ahh , so probably a thrust washer issue . Dusty
Yes, believing a company should sell a product that doesn't stall while riding is so beyond reasonable. Maybe if I smoke the magic fairy dust I won't care.
No, he's wasting his breath because you've demonstrated no willingness to listen to anyone here.I'm really not interested in addressing your complaints any further for that reason. I was only commenting so MechSav would realize there are options.Like I said, have fun tilting....
Yes, it should have been sorted at the dealer, but much depends on the skill set & accumulated experience available there to diagnose problems. It seems to me, operating from a position of abysmal ignorance & stabbing in the dark, that those error codes point you in a direction. One or other (or both) those speed sensors are playing up, or their handshake to the ECU is. And something in the FI module is wonky. The dealer should now have something to work with. The dead spot at 4,000rpm may be connected, or may be another thing altogether. I had similar on the V7C (different ECU, mind) - dead spot at around 3,500-4,000 rpm, first started at about 40,000km, and persisted until I swapped out the TPS at 170,000km. No dealer, or anyone else for that matter, had much of a clue. It's all black magic in there. The problem with the TPS (a simple potentiometer - so when the throttle is operated, the effect should be linear) seems the be that a flat spot had worn there and at about 3,500 - 4,000 rpm the effect was no longer linear. There was never any error on this logged in the ECU. I didn't find it until I determined to test each sensor - and the TPS happened to be one of the early ones I got to (and learned how to test).In a perfect world, it should all work right straight out of the box, forever. In the next perfect world, any problems should be easily identified & easily fixed. But it ain't perfect. And now that I've finally got the V7C running really, really well, the clutch is slipping again. But I've an idea why (a failing seal) and know how to fix it.
Thanks, going in on Monday. Didn't even think about the TPS (as my problem has been there from the first ride home). It isn't noticable in lower gears but in 5th or 6th it is as if your hand slips off the throttle at 4100rpm. I tend to think it is simply running far leaner than it should simply by the smell of things.
Bitching and moaning on the internet may make you feel better but its not going to get your bike fixed. SIMPLE MATH... Its throwing check engine light, not running and under warranty = DEALER. You're welcome
