Probably a 98 that was called a 99, don't think they made any '99's.Pin 28 would be on the big (98) cpu, no?
Dusty,98 & 99 EVs were virtually identical -equipped with P8s. Changeover to P15 in 2000. James mentions pin 28 as the grounding pin for the pump relay which is correct for a P8. P15 doesn't have a pin 28. Electrical diagram for 98 EV as shown on This Old Tractor site is incorrect as it shows a P15. The diagram for a 1996 1100i should be used for the 98 & 99 EV.Time flies. I bought my EV new in 1998 - It's hard to believe it will by 20 years old in a couple of years from now. Obsolete by today's standards.
Yes, needs fuel in it for lubrication.
The relays are original but they seem fine.
I am still curious what tells the CPU to put a ground on that pin 28. If it is just the key being on then it seems a little useless. Why not just ground it and be done with it. I did read somewhere (can't remember where since I have more miles on me than the bike ) that when you close the throttle the fuel pump stops to help with the deceleration. Seems odd to me since that same circuit powers the coils but maybe that is why they have that connection. Come to think of it I guess no power to the coils would help with the deceleration too.
I wonder if Guzzi ownership can help prevent dementia, I mean, you have to use your noggin to keep one runnin', right?
The fuel pump doesn't stop at idle (the engine needs a constant, pressurized supply), but there is definitely a change in the pump's spin rate as you move the throttle off or onto idle. I don't know if the ecu is speeding it up (can't see a control circuit for that in the diagram) or if the increase/decrease in flow at the same pressure is making the impeller change speed. But it does happen.
Correct,RK... Voltage increase when the engine speeds up causes the fuel pump to speed up. Watching the voltmeter on mine shows it quite clearly. Terry
Not quite . . .The fuel pump relay is controlled by the ecu. The ecu sends it a signal when the key is turned on for that 3sec prime. Then it shuts the pump off until it senses the engine turning at some speed. Once it thinks the engine is running it returns power to the pump. If the engine stops turning the ecu shuts the pump off again. If you want it to reprime you need to toggle the kill button.
The ECU isn't wired to the pump, all it controls is the relay, perhaps it may have some control but only by not firing the injectors.
OK , but if my Jackal starts for a second and then dies in cold weather , the pump primes again W/O any input from me . Just figured it was because the pressure had lessened . Dusty
