hahahahayeah, rightHey, that's the way their shop manual shows it. They have a bare engine on a bench and the valve check/adjust looks easy at that point!
Not to be a snob, but the extra costs are worth it.
Oh, no problem. All you have to do is pull the engine out, put it on the bench, adjust that rear cylinder, and put it back in. <shrug>
Well, at the other end of the spectrum there's guys like me who think if only I had the option to have a Pete Roper or Harpers working on my Guzzi in SLC, Ut. I wouldn't bat an eye at those costs ...
This is where we are with the 696.Granted Jenn doesn't put a ton of miles on it, but we're past the first check now, only do belts every 4 years or so and we've not had a single problem with it, unless you count that we mysteriously had to bleed the rear brake this year after winter storage with no sign of why.
Yep. I've owned one Ducati and have ridden quite a few. I'll own one again, and yep, the extra costs are "worth it".
Mysterious air appearing the rear caliper of a Ducati is "a thing". On my 620 Multistrada I had to bleed the rear brakes at least once or twice per year. No apparent reason, no leaks or loss of fluid. Just lost the pedal. Many others report the same thing. At least it is easy and quick to bleed them.Cheers, Tim
Is the rear master cylinder, not the remove reservoir, located below the master cylinder ?
Sometimes a system with a lower master can cause drainback from the caliper into the master cylinder and a spongy pedal.. Generally, they may have a check valve of some sort to prevent this...Perhaps over time during storage some fluid drains back...
But where/how does the air get in?
As I said, it is a thing. No logical explanation. It just happens, "mysteriously"!!!Cheers, Tim
I found on my 996 that tightening the rear caliper bleed nipple slightly tighter correlated to the issue going away. Whether that was the cause or if was unrelated I don't know, but the rear brake previously needed to be bled after a period of storage, now it does not.
Ever tried to bore out and replace a snapped bleed nipple ? Taking it out and carefully cleaning the tapered end and replacing it is a good move.
Yes, and I'm sure I did that before tightening the bleed nipple slightly tighter. I've been working on motorcycles, cars and airplanes since 1974.
Not so much air as the slow seepage of fluid retracts the caliper piston and makes for excessive travel... Do you see or hear the air when you bleed it?
Yes mate it's ok... really. I broke one off on a GT 380 in 1977. Made a dogs breakfast of the repair back then. Done it since ok though.
Most definitely air bubbles. Also to add more mystery, my bike was never stored. Ridden all year round and almost daily. It just happened, no rhyme or reason to it.
Most definitely air bubbles. Also to add more mystery, my bike was never stored. Ridden all year round and almost daily. It just happened, no rhyme or reason to it.Tim
Then you have air in the system, it's that simple...
At the end of the day, I suppose it's all relative anyway....with motorcycles and most FUN hobbies....and as the old saying goes: "If you want to PLAY...then ya gotta PAY!!" :1: As far as vintage Ducati's, I always had a "Jones" for this one...
Then the million dollar question is: How is it entering the system? If the seals or bleed nipple were leaking then surely there would be brake fluid loss, especially under pressure of braking.Master cylinder reservoir was always full. I don't disagree that air was getting in but where?Tim
