There's a pretty good bit of noise from the valves, but I guess that's to be expected from an MG even if all is well?... Does anyone know if Matthews is a decent shop?
If they said it was rollerized, and it turns out it wasn't, then surely you are entitled for a full refund or rollerization on their dime.Get a bit stroppy!
At 10K there will be signs of damage. Even one speck of DLC missing is cause for replacement.
Maybe not. At 39,000 miles when I had mine done, the DLC was a strange mottled color, enough to indicate heat and problems and convince Guzzi to cough up a "C" kit, but no DLC was missing. Lannis
Strange mottle colour is damage. No if's or buts.End.
Well, not quite the end, since I'm still here and posting.The flat tappet surfaces were still smooth. It was not pitted in any way, nor under a magnifying glass was there any missing material. My valve lash had not changed at all since the first adjustment at break-in time.That may be classified as "Damage", but I believe the statement that there was no missing material is correct. In this context, that also means that there were no hardened fragments of DLC circulating through my oiling system.As a matter of fact, Guzzi was trying to deny the claim for the kit when they were first sent the data and the photographs. Fay heard our dealer arguing for the claim with Guzzi like a Philadelphia lawyer, and got disgusted at Guzzi and went and bought us a Triumph Trophy 1215, since I had already taken the position that if Guzzi denied the claim for the "C" kit based on "no missing material" as they first said, I was going to part the bike out and forget it and Guzzi.However, "Scoot Richmond" saved the day, the Stelvio has gone 10,000 miles on the rollers doing yeoman service now, and we have one more transcontinental two-up touring bike in the garage!Lannis
Lannis, the mottling is caused by the DLC crazing. I believe the reason why it crazes is because at certain engine speeds the beehive springs will surge, the tappet will leave the opening flank of the cam and then hammer down on the nose circle. Why else would the first cam damage appear on the nose circles? The point of greatest pressure and therefore where you would expect the first damage to manifest itself would be at the base of the opening flank where the cam is being asked to suddenly start accelerating the combined mass of the valvetrain, very quickly, but the opening ramps and flanks are the last bits to wear.The difference in wear on different tappets can be put down to tolerance differences in the springs themselves, some may suffer worse than others from surging.If you look at pictures taken with an electron microscope the pattern of delamination is clearly visible as it advances. The surface of the tappet ends up looking like a mosaic before the DLC actually comes off in chunks. The fact that there may not of been any steel substrate exposed does NOT mean the tappet is serviceable.Pete
As others have noted, pull the valve covers and take a look. That's dead simple. If you do not have rollers you need to have the shop pull the lifters to inspect for DLC damage. At 10K miles you might not have enough wear to get replacement under warranty...it's a crap shoot. I had my local Guzzi shop replace my flatties and Guzzi refused to pay for the parts. There was obvious wear to the DLC. This dealer was in the process of dropping Guzzi so I was left holding the bag...$1400 worth. Let's hope you have rollers. If not, decide if the bike is a keeper.
The VIN is ZGULSU025CM111668, and the number on the engine is 813692. My understanding from reading these forums is that mine is one of the failure prone flat-tappet bikes, right?.
According to Piaggio, Roller tappets are in the following engines.Stelvio AC : After AC12596 03/12/2012Griso A8 : After 13524 04/12/2012 Norge AA : After 12214 04/18/2012
I have a 2010 which was a flattie! I liked the bike and with the aid of a local Guzzi shop got a "C" kit as warranty item. Did my own work; about 1.5 hours per side. So, if yours is a flattie see if you can get a kit and do it yourself. Even if you do not get a free kit the bike is worth it as long as you do the work. FYI, mine was at 10,500 miles and it had the discoloration and hazing mentioned above.
Well, I pulled the valve cover and took pics, even though I'm not entirely sure what flat versus roller looks like, from this angle. The pics look like they could be rollers, but again, I've not found any detailed diagrams of the comparison to make that judgement. Fingers crossed; can it be discerned from this pic whether it's a flattie or a roller?russian image host
