Knowing that there a few owners of BMWs on here, I'm looking for suggestions as to a new battery for my 1993 K75 without ABS brakes. I bought the last one from the dealer, and paid @$150.00 (traditional lead acid). It lasted four years. I'm loathe to purchase a lawn and garden battery, but why not? Any suggestions as something more reasonable than $150 and maybe not so so low ball as a L & G?
Westco batteries - AGM (no leak, ship ready to use), I've gotten 5-6 years out of them. Reasonably priced. Quick shipping. Used in all my BMWs - airheads and the K75 Teresa used to have.
Can't help on the battery but since the topic of the K75 is up, I'm going to check one out tomorrow. It is a K75S but it has low bars and was wondering about getting them up just a little higher.I was going to ask about the maintenance, especially the spline but is there anything else I should watch out for? 1994 model.
The splines are a biggie. The water / oil pump is another area to check for leaks. I had a starter go bad on my first K bike, but that's rather unusual. You probably know that these things are pretty much bullet proof with the proper care, and are known to go 250,000 miles or more. Oh yeah, check the oil sight glass. For some dumb reason, people like to over fill them. The center dot is ideal. Anything over the top line is too much. My K75 burns some oil, but I've been told by friends that this is normal.
Sorry for the OT. I plan to have the rear wheel taken off so I can visually inspect the spline there so that I have some sort of hedge against something that is worn and ready to go right after I get it. The bike is at a service shop so I'll just pay for the time it takes to remove the rear wheel. I figure money well spent if it helps avoid the biggest of possible problems.
The splines that need checking on a K75 are those at the ends of the driveshaft. And the biggest problems have been on the clutch output side of the shaft. Not gonna be able to check that with just pulling the rear wheel.Best,Carlo
:+1 Yup, it's a bit more work than pulling the rear wheel. I'm getting ready to do mine for the 4th time (every 15K) not a particularly difficult task, just time consuming. Ditto, on oil level, just a bit below the red center dot. I use synthetic 20/50 in mine and change oil and filter every 5000 miles, doing the transmission and rear drive every 10,000. Check the valve clearance every 15K though very little shim changing is needed. Change fuel filter in tank every 15K as well. Averages 45 mpg. K&N air filter which is a bit of a pain to get to. Yearly brake flush and coolant every other year. Good, solid bike that is very comfortable and reliable though not what one would call "exciting". Great factory saddlebags.
