I consider myself a decent mechanic/troubleshooter. BUT!!!I give up on my headlight/taillight voltage! I brought my bike to a shop to try and find the problem.1972 Cb 750 chopper. When turn key to on position voltage at headlight is 9.6voltsBattery is 14.4 about when engine running. 13 volts about when engine turned off.When I turn key to start position ignition voltage drops from about 12.8volts at the ignition to like 10volts if I remember correctly.I thought it might be a bad ignition switch so I replaced it. Same numbers. Ground wires seem fine at least the one main ground wire. Anyways I threw in the towel and brought it to a shop. Anybody want to guess what the cause ends up being? I should know in about two weeks as shop is pretty busy. Note the taillight is also very dim. I forgot to check voltage there but it is very dim like the headlight. So dim headlight, dim taillight, good ground and switch seems ok and I don’t think taillight is wired through headlight switch???? Let’s see what the shop says.
Something is providing too much resistance and drawing down the voltage. I would disconnect the light and measure the voltage at the connectors to see if it is somewhere in that circuit. If not then it is in the light itself.
It’s in the circuit and not the light as voltage at light plug/wiring with light disconnected is 9.8 volts. I just don’t know where in circuit but I’m thinking bad ignition switch! Il see if I’m right.
I'm thinking bad relay.
I would have done a load test on the battery before anything else. Relay replacement next.
Bare bones wired chopper. There are no relays in the wiring system
In an effort to participate in the conversation, I will mention that the last time I found mysterious rear light issues on my bike, eventually I found wires inside the light housings that the insulation had melted on, and they were making tenuous contact. I addressed that issue and the problem went away. Never did figure out why they melted.We now return you to your pertinent conversation, which is already in progress.
I’d be interested to see a wiring diagram of the bare bones chopper.
Maybe in the wiring from the battery to the switch and back. I’ll bet there’s a lot of vibration under the tank. Also check the ground points for the forward wiring, coil etc on the forward frame area. Also maybe in the headlight wiring harness. I keep hearing about this chopper but need some pictures.
Thin wires, corrosion in connectors/switches, poor earth return.
Beautiful chopper. Thanks for the pictures. That’s as authentic as it gets.
