Built by Tony Foale.http://www.guzziriders.org/id-this-bike_topic3781_page2.html
Well - I just acquired most of a V11 why put a round head in a spine frame? /91b73f0b6cc28922e522b30461fa9d9e.jpg[/img]So - thoughts on this fun project
You'll note that the photo is an original style Daytona engine/frame with a later V11 Sport six-speed gearbox and matching V11 Sport rear drive unit. Not sure exactly what you have in mind, but as I recall the engine was originally shifted sideways to allow use of a five speed gearbox with a spine frame and 160 rear tire, but the six speed gearbox designed for the spine frame eliminated that necessity on the V11 Sport.I saw a '97 injected 1100 Sport with a six speed gearbox in 1998... at the factory in Mandello, all hacked up to fit with thermocouples and data logger taped to the tank.Cool stuff, Mandellese style, pre-takeover.
V11 Sport six speeds and later six-speeds are different, and I don't recall hearing of anybody using a later six-speed gearbox in a spine frame bike.
IMHO a 5 speed trans. is better than a V11 6 speed. A later 6 speed feels better than both but may be harder to fine and fit. I'll leave that to others.
Make sure the frame has a brace for the transmission. If it was a red frame you'll need order a brace.
..... You could go off the deep end and see if you can still get a Ghezzi Brian racing frame that will allow a five speed with the anti jacking system combination.The other aftermarket bit that might be worth thinking about is a Magni paralellagramo if youa sk them nicely they might even build you a frame, you have n't mentioned any kind of budget.
It's fun to spend other people's money.
I would send the heads to Mike Rich Motorsports for a freshen up and some porting, both engines. You won't be sorry!
Five speed is better than the six???? in what way exactly the six speed is stronger, much more modern, and a hell of a lot better to actually use. Just make sure the spine frame is straight before you get too far it will handle vastly better than the tonti ever hopes too.
There was a pull down report for the 6 speed not long after it came out (don�t recall where I read it) allegedly the V11 box was designed to put much more power through it than the V11 engine offered. Of course change in ownership etc led to the Breva box.According to some the 6 speed bikes FELT faster.Interesting re handling, I figure the spine frame has more clearance but never noticed frame flex on the Tonti? early �80�s Suzuki�s were way worse in my experience
There was a pull down report for the 6 speed not long after it came out (don’t recall where I read it) allegedly the V11 box was designed to put much more power through it than the V11 engine offered. Of course change in ownership etc led to the Breva box.According to some the 6 speed bikes FELT faster.Interesting re handling, I figure the spine frame has more clearance but never noticed frame flex on the Tonti? early ‘80’s Suzuki’s were way worse in my experience
So six speed boxes are : V11, Breva and Griso 1100. I know there are differences but wondered if dimensionally they are the same in terms of length and width between the input and output shafts?Sent from my iPhone using Tapatalk
As far as I know the Breva 11 got a different box to the V11. Only reason I *think* I know is the dealer let me ride a demo bike while my V11 was in for service. The shifts seemed slicker & the guys told me it had a completely redesigned box. Caveat: I don’t know what year the newer bike was.I did two springs in my ‘03 V11, didn’t touch them on my Scura (some 40k km) & my new 55k km V11 hasn’t needed the spring either.My comment re the six speed feeling faster is reinforced by a second hand quote from Dr John when the V11 came out - allegedly he said they were not any faster than the injected sports. For me it’s only about your rear Tyre size, Magni showed me one of his special order bikes for the Japan market (52 made?) & pointed out the 180 rear using his frame.Probably worth mentioning, the early V11 ran a 160 rear, the box was then offset to accommodate the 180 (& swingarm looks like the pinched it to widen it).Blokes have fitted the six speed boxes to the Daytona but my modified racing ran a 180 rear with a 5 speed...So many choices/complications
and the car will wait....
