Background... I got this bike in Dec, and I hadn't rode it first... So Ive been going through it, getting it running better, and keep finding things. So it has free flowing mufflers, and open airbox.. Clearly ran like it was not fueling right.. Ive been going through it all, making all the adjustments and have it running good.. Kinda.. So now my idle speed is too high.. So Im going back to the TPS, TB setup procedure and I was checking to make sure the fast idle wasn't engaged.. So as Im checking I found that the second return cable to the twist grip was so loose the feral was out of the bracket!!! So far Ive found the TPS way out of adjustment, the balance all off [had way too low idle when I got it] and now this.. So im guessing whoever did all the mods just adjusted a lot of shit blindly to get it running right!! OK, so that being said... I cant find a adjustment procedure for a 02 California throttle cables.. Right now I adjusted them so I have just a tiny bit of slack on the pull... and a little extra on the return. Is there any spec??
All in all every change I make makes me love this bike more!!! Going to redo the TPS, and TB balance now, and get some miles on it with the new map I loaded into it..
