Ok, a bit more oddness. I added transmission oil to get back up to the weep hole.
Here's the diagram:#6 o-ring can be pushed over the splines and fits nicely in the grove right behind the splines on the input shaft. Kind of like a notch on the shaft made for it.#4 was the mystery o-ring for me. I couldn't find anywhere it would come to rest. So I placed it on the input shaft splines, then pushed the clutch gear hub into place, hoping that pushed this o-ring back and into the proper place.The other mystery, I did not have washer #7. My Quota had 20,000 miles when I bought it, and it was obvious no one had the motor off the transmission before. So I didn't really want to add #7 if it had never been there before. Guessing maybe this is where I messed up and now have a transmission oil leak. Will probably pull it apart in the next week or two to see. GG - let me know if yours has washer #7! Or Patrick - do you know if the metal washer #7 is supposed to be there? Should I add it if it was not there before? Thanks
So I tapped the lock washer prongs flat. Put my homemade clutch hub holder tool on, put the 4 prong "socket" tool on my torque wrench, carefully held the 4 prong socket against the hub and got it to 90 nm.
You're only half way there. Does your torque wrench have both metric and SAE torque readings? 90nm converts to 66ft-lb. The specification for input shaft and output shaft is 115-129 ft-lb. You need to develop a LOT more torque to finish this job. Like 160 nm.So, your clutch hub was loose. Did you fully remove it to inspect the seal surface? Inspect the two o-rings?Should you disassemble the clutch and inspect/clean the plates? Your option. In theory, any oil that might come up the shaft and leak out the center of the hub would be captured by the hub's forward lip and sling or drain out through 3 holes in the rear or inboard/hidden face of the clutch hub. By doing that, the oil would sling out into the empty bell housing rather than down into the clutch disc sandwich. Perfect system??? You have the flywheel lock and the clutch compressor at hand. It would only take a few minutes to pull and clean t he clutch parts. I would try a good solvent and then soap/water bath to clean the plates. I wouldn't toss the new plates. Just my opinion.Patrick HayesFremont CA
Hum, I had notes that said that should be 100Nm.
Wow, that will be the tightest bolt I've ever done! How did you get yours that tight on the EV? Is there some other nut option other than this 4 pin one? Just seems crazy to have a someone fragile arrangement on one of the highest torque value bolts on a motorcycle. Thanks
Here's the diagram:The other mystery, I did not have washer #7. My Quota had 20,000 miles when I bought it, and it was obvious no one had the motor off the transmission before. So I didn't really want to add #7 if it had never been there before. Guessing maybe this is where I messed up and now have a transmission oil leak. Will probably pull it apart in the next week or two to see. GG - let me know if yours has washer #7! Or Patrick - do you know if the metal washer #7 is supposed to be there? Should I add it if it was not there before? Thanks
I got do not see metal washer #7 either. I’ll check again after I get the seal out and have a better view.
Also called a 'throwout washer'. It sits on the shaft BEHIND the input bearing and rests against the inner face of the bearing. You won't see it until you open the box and remove that shaft. I erred when I wrote above that you could see it in front of the bearing.
