All four of mine flash, so did those of the G5 I just rewired. The dash warning lights did not flash with the "4-ways" though, only with the signals. Probably just a matter of moving a few wires to different positions.
Interesting, my dash lights work when the switch is engaged. The Owners manual identifies that switch as 'rear emergency flashers', and the wire diagram I have (c.1975) also shows the connections from that switch going to the rear lights. I'm sure it is easily modified to flash and jumped to the front signals though. I have this colored wiring diagram that has been very helpful in sorting out some of the wiring issues. Also have in PDF with much higher resolution.
Started to dig a bit into the Convert.Bike is running K&N pods with T3 airbox, Stainless Exhaust from a Bassa, Ikon rear and FAC front suspension, Alt spacer. 43K miles. John (PO) had the bike re-jetted when he did the swap over. He owned the bike 15 years, bought in 2005, looks like from West Virginia.Working on identifying the drive plate, and checking the hex drive. I've been able to find pics of the pressed plate, but not the cast. Does the cast drive plate have a curve like the pressed? Is the pressed plate really thin tin? I initially thought it may have the pressed plate, not so sure now. Cant really tell from this.No winglets or rear seat cowl, but that's fine I would have removed them anyhow.Bike also has what looks to be an aftermarket rear brake pedal. It goes under the footboard. Has to be unique. John didn't put it on the PO to him must have, as well as addressing the drive plate. Likely isn't original with 43K miles. John only rode it about 6K miles the 15 years. img world I've pulled the Windjammer and bags off, plan to put a stock style headlight and directionals up front, solo seat, and DB bags back on.Plan is Bucket supports and CEV directionals/stalks from MG Cycle (without side reflector), and an H4 Hella housing with the Native ADV bulb. Seat from Harpers. Not sure if I want a rear rack or not, or swap the crash bars out for chrome. Time will tell.Will use the lights in the bags for directional and extra brake light. Instead of playing the snip and solder game again if I decide to put the Vetter back on, I am going to wire in a heavy duty weatherproof pigtail connector to the headlight and turn signal bundle, and the harness on the Vetter, and have it's mate on the bike. This way if I decide to put the Vetter back on will be a plug and play affair. Here is how it sits, have the front loom open to start wiring in pigtail, and the rear fender cleaned up nicely. By no means a perfect paint job, but a little patina is nice on a classic.
Carl Allison's diagram? I've seen that one and several others. None have exactly matched any of the (four) Converts I've owned.
Really nice work Bulldog! Those bags are great.
How nice!Looks like nobody answered since you asked, so: we installed an Outsider kit when I had my new to me Jackal a few years ago at Hamlin's shop-did a few other things as well. 6000 miles later all is good.
All I could think of when I saw my vert/DB bags from this angle?Big A$$ Bottom Betty is your name...love the spit and polish, and finish your getting to here, bravo!
**OK hate to ask an oil question, but.......... I run Bran Penn 20w/50 semi synthetic (The PA GREEN oil) in my P cars. It is high in zinc and all that, similar to the Valvoline racing VR1 (which I have also used) I have a case of it, and would think it will work well. With a 2K change schedule, this could be expensive, but oh well. I've also used the Rotella non synthetic 15w/40, anyone running this in the older Tonti or Loops? or something else. DONT want to turn this into an oil debate thread, just want to see what others are using.
Filter change is recommended at 9K
Oil change every 2k might be a little overkill.
I believe "The Manual" back in the day of no filter called for 3,000 mile dinosaur juice changes, I suspect they just didn't bother to modify the mileage with the advent of filters. With the smaller UFI filters they recommended filter every other time. When they went to the larger filter (which I believe applies to the Convert, but I could be mistaken) it was still 3,000 for oil with filter every 3rd, indicating that the factory thought the larger filter was good for 9,000 miles.What I have found convenient (with an outside filter adapter) is oil & filter every 5,000 miles. That lets me just use the odometer as a simple oil change reminder: 10k, 15k, 20k, etc. change oil & filter. Purolator filters from the local auto store are cheap (and good) enough for me to not think about it any further. In my Sport 1100 I have always used full synthetic and have recently switched to 10W60, I have found that it does make a difference stuck in traffic on a hot summer day. I have a dipstick thermometer and an oil pressure gauge, sometimes more information can be a frightening thing.As always, your motorcycle may vary.Howard
Gotta say, that's the nicest Vert I've ever seen. I'm not a fan of the DB bags, but they look so right on that bike.Well done Steve!
By "wings" do you mean the ones on top of the front crash bars? I love those, and very rare to see. Put em back!
