Here's a link to Bill Havens adventure into re-sealing his throttle bodies due to fuel dripping from the throttle shafts and possible worn bores. Sounds similar to your dilemma. Hope this helps. https://wildguzzi.com/forum/index.php?topic=73658.0 Paul B
What? No QD (so called) fitting? If I were you you, I'd be giving Pete a ring.
ThanksWill do tomorrow
The 'trick' is to unplug the Pump Connector, then try to start the Engine.This depressurises the Fuel Line, making it easier to disconnect the Connector.
As Doc says, this makes it much easier, the engine might run for about 5 seconds.
UpdateCleaned Airbox in parts washerCleaned throttle bodies with Carb CleanerSurprising amount of oily gunk removedfelt so pleased with myself I made myself an espresso coffee (1955 Svea 123 petrol stove)
