Goodman builds a good economical unit . You will likely have a problem matching the new 14 SEER condensing unit to your old 10 SEER A coil . Dusty
No thoughts on Airco . I would check around and find out which local guy is recommended , you will normally get better service from a smaller company . Also , no real thoughts on Lennox , my only real experience was with Heil and Goodman , and Heil isn't what it once was . About replacing the air handler (furnace) , if the new unit will fit in your existing closet , it probably makes sense to do a complete change out . The new A coil will not fit the old air handler W/O a transition chamber being built , and your old system is 30 years old . The labor will run about the same, or should either way , the hard part is getting the old A coil out and the new one installed , the furnace is easy . Dusty
My local guy wants to replace the furnace too. And it's not too old.
Ask him why . Dusty
I replaced my a/C unit about 8 years ago. They inspected the furnace and said it was fine and replaced the coil and bent new ducting for it.The line about the warranty is just to sell you a furnace.How old is your furnace and does it do a good job?One other thing. Get more a/C than you think you need. Not much but a little bigger. That way on real warm days with guests over and the stove and oven are going the a/c has enough capacity to handle it.
Furnace works good. I've had it for a few years, maybe 10. I'm told American Standard is a good gas furnace. I've replaced both furnaces, I think think other one is a Ruud. They both seem to work fine with the old Lennox air units. I can't see why it would be a problem with a new one. I can get the Lennox 16 SEER unit & coil for $5650, installed, permit, fuses, etc., all in. They can put it on Monday, so I bet they might go down a little. The original 3 ton cools fine. So I expect this 3 ton to do as well.I've never purchased an air unit. The heaters were emergencies. Funny it's freezing here now.
John , is your electric provider giving any rebates on new 16 SEER condensing units ? Does the install price include a new copper line set ? As mentioned , the newer units run at higher head pressures . Dusty
Thanks Barry, I think we're on the right wavelength. I've got several higher cost options. The 16 SEER is only a couple hundred more than the 14. The others go up by $1000s. Now whether $5700 is worth it...I dunno.
My main air conditioner needs a compressor. It's apparently not economic to repair due to old freon technology. I'm not complaining since it's nearly 30 years old. We've been able to keep it going for the last 10 years or so with regular repair and maintenance. What I need is a complete replacement for coil, condenser for 3 ton unit. I've gotten estimate from $6k-$10k. The furnace is in good shape and is American Standard that we replaced a few years ago.My bedroom unit is a 2 ton and his holding up OK. It needs a half pound charge or so that last couple of years. Any advice appreciated regarding expected costs, best brand or repair of old unit. Thanks guys.
LowRyter, Greetings from Illinois. You are always providing good advice and entertaining posts, so trying to One Back At You. Will try to keep it boiled down, but there's lot to toss on both sides of the scale. There's a somewhat inexpensive alternative to replacing the whole system. if all you need is an outdoor "condensing unit", ask your HVAC guy about a "R-407 dry ship condenser unit". If you can still obtain one, they are essentially an R-22 outdoor unit that is shipped without any refrigerant in it, and specified as for use with R-407 refrigerant (blend of refrigerants totally compatible with R-22 systems, but it doesn't contain the CFC molecules that deplete ozone). R-407a condensers are a loophole exploit for the past 5-10 years to perform an outdoor unit replacement on old systems, for economy reasons. They have been Manufacturers' way of continuing to produce R-22 "parts" minus the R-22 "Freon". Residential HVAC companies don't like to tell peeps about the exploit 'cause there's not much money in doing an outdoor unit swap out. A few of hours capturing the R-22, cutting the dead soldier loose, wrestle the R-407 unit into place, wire, torch, evac and charge it up with R-407. Done in an afternoon.But if your compressor failed failed due to refrigerant leaks, or electrical burnout, you need to bite the bullet and go whole hog with a new A/C system; Indoor coil, outdoor condenser, and the copper line set between them. Reasons:-electrical burnouts skunk the oil inside the system and create acids that will damage your new unit or system. If the system is fouled, don't bother with an outdoor unit swap. Replace the works. -Oil Incompatibility - R22 refrigerant is over. 2020 is 1st year that it cannot be produced or imported into the USA. What's here is all there is forevermore. So, modern units use a refrigerant called R-410a and an ester based system oil which is not compatible with the mineral oil that has been whipping around inside your current a/c system for the past few decades. There is no real way of getting it fully purged from the pipes, and you'll be pissed if the old pipes are "flushed" and reused with a new system to save a few hundred bux only to leak refrigerant down the road. Liken the oil thing to the diff between DOT-3 glycol based brake fluid to DOT-4 silicone based brake fluids. The oils don't play nice with each other. Nasty things happen inside your expensive new system as a result. If your choice becomes New System, also be aware that -R-410a systems are physically much larger in size than what you have. The outdoor unit will be nearly 2x larger, and the indoor coil abt 25% larger. Nothing wrong with that, unless footprint outside and available space between your furnace and ductwork is an issue. -R-410a systems operate at 50% higher pressures than the old R-22 systems ran. Argument #2 that a new copper line set is appropriate.AND, -R-410a is ozone friendly, however it is a monstrously bad greenhouse gas. Top of the list of the worst. Talking thousands of x worse than CO2. Because of this, R-410 is slated to be phased out over the next couple of decades. The best advice I can think of re: new system - keep it as simple as it can possibly be. You'll be bombarded with whiz-bang features, touting efficiency to the moon but don't swallow the hook. What you have now lasted for decades because it was SIMPLE. The difference in efficiency doesn't mean a darn thing when a circuit board fails and you have to sweat it out for a couple weeks waiting for a high dollar circuit board etc. Service calls ain't free, amIright?So far as equipment - Goodman and Amana are the same thing. One is jeans, the other a Tux. American Standard and Trane are the same thing. Am Std=Jeans. Armstrong and Lennox are the same thing. Armstrong=jeans. Bryant and Carrier are the same thing. Bryant=jeans. Last thing. Warranty. Not changing your furnace with the air cond system has zero effect on the warranty for the a/c system. Anyone who says different is blowing smoke.
I have a thirty year old Trane system that touted a seer of 10 which was high for back then. My buddy lives in Arizona and has bought split units, three with one head and one with five heads. The inside head units can go on the wall, in the ceiling, as a picture frame and even on the furnace as a A coil would. His have gone in three different houses and all have SEERs that are high twenties. He sized bought and installed them all with basic mechanical skills and then hired a AC guy who did the start up. They work surprisingly well as I saw them in action when I visited. I am seriously considering on splitting my system when it finally fails. I want to aim for the combination heat pump air conditioner.
