I bought a bottle of Rislone oil supplement with Zinc treatment to add to Fuchs Silkolene motor oil I'm going to use on the next change. The bottle says for motorcycle engines to use . The bottle of Rislone says it's a 3x concentrate and that it's 11oz works the same as non-concentrate 32oz. I have no problem no far, what I'm wondering about it the ratio to oil they recommend.For motorcycle engines it says use 2oz per quart of oil. That seems like a lot of additive to oil to me, what do you think?
It may be fine, but I figured why risk it. As far as I’m aware no current oil available in NA contains the anti wear zinc compound that is best for 1200 and older motors. Calling Chuck, come bail me out here!
Didn't I read somewhere that our roller motors have less need for the additive that flat tappets? Not none-but less.Someone help me here-thanks.
I'm curious RER, what the api rating was on your test oil , SM, SL, SG?? Paul B
Oil companies spend a lot of time/money engineering oils to perform like they do. Of course Joe blow in his garage knows more then them in the area of oil engineering.. You will not improve top tier oil, and probably would not do much for the bottom rung stuff either..
Yak fat! Always has been the best! Always will!
