Couple questions.
What is the proper way of setting these? I never counted the threads sticking out on either side. Right now I have it where it swings freely and the shaft does not seem to buckle when turning.
Also the bearings which are FAG 539816A, how should they feel. They are not crunchy but does feel like the inner race wants to pull out slightly, once I push on the inner race and press in it feels good, but if I use screw driver and turn it from the inside it seems loose.
I am getting bike ready for national but if I had more time I would order a set just to make sure.
Also how is the U-joint greased? It feels great and I noticed that inside the housing there was a little grease splatter but I see no grease fitting.
