The Skorpion manual sez to put the bike on the side stand, and measure 30-40mm. When checking the oil, it also says to put it on the side stand. .but it needs to be on the center stand to be correct. SoHow is a chain "normally " checked?
How is a chain...
Chuck,If you walk through the pits between races at a professional flattrack race, you'll see most everybody setting the chain slack by keeping the bike on the race stand, rotating the wheel while pinching the handle of a mallet between the chain and the sprocket--then pulling the wheel back to take out the slack, and then tightening things up (being careful to make sure the axle is exactly the same on both sides). That's it. I've never seen anybody measure anything. These are guys who change sprockets and swingarm pivots between every heat. Incidentally, the mallet is used to whack off the sprocket and brake disk with a quick-release hub.
Bike swing arms generally or always move up and down on an arc...The chain is best adjusted when swing arm is at the "longest" position because of the "arc" And rotating the chain within this to find the tightest point..For all the street bikes I have owned it's done best with the rider seated on the bike and not on any stands... and about an 1-1/4 inch chain slack...Shifting problems on some bikes are because of a too tight chain..
I don't know if chains would wear unevenly, but I do know that sprockets can be manufactured/mounted off center.
I’d agree about uneven chain wear except that new chain and sprocket sets do not in my experience vary in slack as they’re rotated, and worn sets do. Something changes. I guess for the purposes of this thread it’s not that important what changes exactly but it would be interesting to know - I wouldn’t claim to have that figured out.
And not one person reminded you to have it in neutral! I once watched a over heated Bmw rider loosen his adjusters all the way in with still no slack. I almost felt bad telling him.
that's been experience. Everything is fine with a new chain and sprocket. And I've learned that regardless how the sprockets look, go ahead and replace them with a new chain. Instead of getting 20-25k miles out of it, it's done in 10.
So while I have you guys attention.. are sprokets standard? It's not like I can just go to my MZed dealer and get some new ones..
Sit on the bike the bottom of the chain at the mid point between the sprockets should have 10-20mm free play. On a road bike 20mm is a bit too much but it puts you in the zone.
JT Sprockets has them for just about anything.http://www.jtsprockets.com/fileadmin/files/JT%20Sprockets%20Application%20Guide%202018.pdf
