let's overthink this now.
Some additional thoughts.If you are going to get new sprockets and chain make sure they are a matched set meaning that they are of like strength ratings. A drag race chain with an aluminum sprocket set will mean quickly worn sprockets.
Some additional thoughts.Don't forget to check chain alignment. I like the Motion Pro Chain Alignment tool.Don't forget to measure the stretch in the chain at several locations.If you are going to get new sprockets and chain make sure they are a matched set meaning that they are of like strength ratings. A drag race chain with an aluminum sprocket set will mean quickly worn sprockets.All of the above is one of the main reasons I am now on a Moto Guzzi V7.
Why will a drag race chain wear an aluminum sprocket faster? I have a DID drag race #530 on my Triumph land racer. wear is not a problem of course , the drag chain is lighter, maybe better steel, but I'm not seeing in my mind the additional wear factor other than aluminum sprockets wear faster than hardened steel no matter hat type steel chain..
If accessible, the rear axle should be measured off the swing arm pivot axle on both sides to make sure the factory marks are accurate.
Yep. Anal intent matched with too much time on my hands...I put both swingarm axle and rear axle in the lathe and created a center mark on each end:Then made a simple gauge out of some scrap aluminum and old political campaign sign wire:This way I do not rely on the hash marks on the swingarm, it's actually faster for me to get the chain adjusted and axle parallel now.
Now as long as the engine is mounted so the front sprocket shaft is parallel you're in great shape. According to forums I have been on the engine is sometimes out of line.
Hows the gearing on the MZ Chuck? Are you going to try a change in sprocket ratios? Just curios, I found changing to a 16 front on my Tuono made it a lot more street friendly.
Are you saying the engine is mounted out of alignment on purpose?
Doubtful, but the owners had to align it themselves. Let's just say accumulation of tolerances, instead of some tolerances cancelling others out.
