I believe the flashing is done by the dash.Yes it may interpret the low current of an LED as a burnt out lamp, just try LEDs in one side to see.
Quick answer, put something descriptive in your title like, "quick question, V7 signals.."
I thought that one of the main benefits of changing over to LEDs was the reduced current draw, but the use of resistors (I have read) nullifies that advantage.
The V7C, at least, has a flasher unit. I remember seeing it. And I bought an LED compatible one early on that's still sitting in the parts box. I'm quite content with the stock lights, especially as now the dash indicator light is intermittent. It helps that with the low bars I can see the front indicators. Note that in 200,000km on the Classic & 100,000km on the Special, I may have replaced one indicator globe, and maybe 3 or 4 tail light globes. Not what I'd call a significant imposition.I thought that one of the main benefits of changing over to LEDs was the reduced current draw, but the use of resistors (I have read) nullifies that advantage.
