It's been a while since l changed mine, but ...Looking at the second picture, it seems both pads are positioned too close to the non-fixed side. I think this can be corrected by sliding the entire fixed bracket along the pins that are covered by the rubber accordian tubes. (Only one can be seen in the picture.) The bracket moved gradually to its current position to accommodate pad wear. With new pads you need to move it back. I would try using one or two small C-clamps for that, carefullyMoto.EDIT: That is, press the gold- and silver painted halves of the caliper together by using C-clamps opposite either end of each rubber-covered pin.If this doesn't work easily you should separate the two halves and clean up the sliding parts.
Good luck, I had the same with a 2010 Stelvio and EBC. I got nowhere and tried everything I could think of to get it farther opened up. I called EBC and they said "they're supposed to fit but..." I finally used the 1/2 worn-out pad on one side and the new one on the other. worked great. let us know if you figured it out.
OK this might be something.... was looking at the bracket to caliper mounting... I'm thinking the placement of accordion boots indicate this thing is supposed to float or move, but I couldn't move it by hand... will try the c-clamps, thanks!
The caliper mount must slide freely on the caliper. (the accordion rubber boots should easily move in and out) It may be rusted and hanging. You should disassemble it, clean and lube the pins that it slides on. If you simply clamp it together, you may cause more issues trying to get it apart. I would pull it apart first and inspect it.
