It's way more than the spec sheet. I do own and enjoy a few more powerful bikes (see list below) with better handling and brakes, etc, and have ridden some properly fast bikes such as the Motus, DucatiDiavel,BMW XR1000, BMW S1000R, Suzuki GSXS1000R.The V7 is a competent street machine that has character, style and class. It yields more smiles per mile than many more powerful machines. I can have more fun on the V7 on public roads than I can on any of the 4-cylinder liter bikes on the list above. On those machines, my reaction was, "Nothing good would come of it."
Well said J. I've had 8 prvious MGs' and 12 Ducs and my stornello and othe rbikes too numerous to mention yet for no reason I can show you on paper my stornello has become one of my top 3 favorite bikes. And Ican barely park it anywhere that someone doesn't come over and comment on what and excellent looking bike it is. Guess you got everytthing under control back there in PA. I miss those good riding roads
Well I can't wait to ride it... Not to cast aspersions but Jay might also be a little jaded from the rest of his fleet.I do think it is hard to compare a smallblock that is just starting break-in with one that has thousands or tens of thousands of miles more.I remember when Jay and I compared his first smallblock (V7C) side-by-side with my then too new V7 Stone (MkI). The Stone felt more torquey at lower rpm, but tight and less free or willing to rev. Thousands of miles later I suspect that side-by-side might have sounded a little different.
I'm curious on the transmission too just because since I added the RK with the 6-spd to the fleet (we already had the 6-spd Duc) I find myself looking for 6th more on the V7.
I was pushing a bit today and ran out of gas at 63 miles past the fuel light coming on. Luckily I was 150 ft from the gas station and it was easy just to paddle the bike up to a pump, looking like an everyday cruiser rider. Tried to start the bike a time or two, I'd died right away, as I rolled or paddled along.Only fit 5.3 gallons in, on the sidestand, to the metal neck part.5.8 gal tank seems a bit of a stretch.63 miles to empty. Anybody else have a number for this?
I posted this a while back. Lately I am seeing around 44 mpg, but it has long seemed to me we get gas here in CA that has been modified for emissions and does not give good mileage.My low fuel light has been coming on around 165 miles.
I put another 73 miles on the V7 III today. I had a lot of fun. What a great bike!It’s near 500 miles now. I was shifting at 5k on the more spirited parts of the ride. It pulls nicely.I put gas in it, 4 miles after the fuel light came on, took 3.97 gallons. So, that’s a lot more reasonable than the 3.3 gallons that the V7R comes on, and 3.6 for the ’14 V7S. I averaged 54.5 MPG today (if the MPG readout is to be trusted). So, that works out to 218 miles ‘till the low fuel light, and another apprroxy 60 miles ‘till dry (assuming total of 5.1 gallons usable as I determined on the racer). So, with 278 miles 'till dry, that’s a safe 250 miles of range. The MPG readout is nice, as it’ll help adjust expected range as MPG varies with temperatures, aggressiveness of riding, wind, hills, etc.
I enjoyed your review jas67. I too own a V7 III special and every ride brings a smile to my face and, in the past, a grimace of pain shooting up my spine when the sub par suspension bits encountering a bump in the road. After several test rides on a V7 III I decided I wanted one in my stable but would need to do something about it's less then mediocre suspension. Prior to delivery last September the dealer installed emulators in the forks. After consultation with Ted Porter at the BeemerShop about 8 weeks ago decided on custom built Wilber shocks for the rear with springs and valving to match my weight and riding style. I installed them last week. The V7 Special, also a purdy blue one, now handles as I would expect any modern motorcycle, without electric suspension bits, to handle. No more wagging of the tail when pushed aggressively into the mildest of curves, and no more bone breaking jolts when riding over even the slightest if sharp bumps, it's a safer and far more comfortable motorcycle now. The only remaining issue I have is the lack of electrons making it impossible to run a Nav unit, heated grips, and a heated jacket liner without discharging the battery. Because of this limitation I use one of my other bike for touring. I will offer that I'm pleasantly surprised by the comfortable ergonomics, especially the all day seat that makes easy work of 800 mile days. Paul
One thing I have not been able to find out about my soon to be delivered Stone is the output of the Alternator. I can't believe it doesn't have enough output for a Nav unit and heated grips. Those two alone should draw less than 8 amps which is only 72 watts. I would assume standard lights and other electrical requirements would be somewhere around 100 watts so if the alternator is putting out 250 or more you should be good.Anyone know the alternator's output?NC
I thought they only made hemispheric heads for the V9, and even that seemed very odd to me - why not go for 4 valves already?With a single spark plug, the Heron head can be quite effective - they usually have high intake speeds and a lot of squish, directing and mixing the fuel right under the spark plug. But the straight head does limit the valve diameter...
My 2014 V7 Special is now listed in the "Swap Meet": http://wildguzzi.com/forum/index.php?topic=96092.msg1520652#msg1520652
The herons have been a limiting factor in smallblock power for decades, the Hemi seems to be a logical and worthwhile improvement.
Yes, but I don't think it makes them any more ecological (and that might be why the stuck with the Heron heads for so long). They could tune the engine for more power with the hemi head if they used dual sparks (which I think they still do not), or simply go to four valves (which I believe they are planning with the V85).
I'm pretty sure it was a very accurate measurement, as I filled right to the metal thing down in the filler both times.
I'll be picking up my first Guzzi in about a week. A V7III Stone. I have heard mixed reviews about the stock suspension but I am not above swapping out the standard rear shocks for better ones. My 2016 Ducati Scrambler had the world's worst rear suspension and I went so far as to buy a shock out of England from Winding Road (Shock Factory out of France makes the actual unit). The bike went from near unrideable to fantastic. If only I could fix the forks . . .So I know next to nothing about aftermarket shocks for Guzzi but at least want them to look as good as they'll ride on a V7III Stone with the blue fuel tank. Yellow Ohlins on a yellow Scrambler? Oh yeah! But on a blue V7III Stone, nah-ah. If you could post here or via PM what your shocks set you back I would appreciate it.Thanks!NC
And did I miss this the first time through:http://motorcycle.com.vsassets.com/blog/wp-content/uploads/2017/08/081717-2017-Moto-Guzzi-V7-III-Stone-hp-torque-dyno.jpgLook at that chart again and think about what you first wrote about not feeling the differences. MOST of the differences occur above 5k rpm not at the point where you run around in gear all the time. And you said you were keeping revs down closer to 4k for break-in right? So it wouldn't have made sense for you to really feel anything at that point. Yes?
I dunno man. It's too easy for there to be air stuck in the corners on the tank one fill and not the other. I bet you didn't sit there and shake and lean the bike a couple of times to make sure all the air was purged.And did I miss this the first time through:http://motorcycle.com.vsassets.com/blog/wp-content/uploads/2017/08/081717-2017-Moto-Guzzi-V7-III-Stone-hp-torque-dyno.jpgLook at that chart again and think about what you first wrote about not feeling the differences. MOST of the differences occur above 5k rpm not at the point where you run around in gear all the time. And you said you were keeping revs down closer to 4k for break-in right? So it wouldn't have made sense for you to really feel anything at that point. Yes?
