I dunno man. It's too easy for there to be air stuck in the corners on the tank one fill and not the other. I bet you didn't sit there and shake and lean the bike a couple of times to make sure all the air was purged.And did I miss this the first time through:http://motorcycle.com.vsassets.com/blog/wp-content/uploads/2017/08/081717-2017-Moto-Guzzi-V7-III-Stone-hp-torque-dyno.jpgLook at that chart again and think about what you first wrote about not feeling the differences. MOST of the differences occur above 5k rpm not at the point where you run around in gear all the time. And you said you were keeping revs down closer to 4k for break-in right? So it wouldn't have made sense for you to really feel anything at that point. Yes?
I'm up to 680 miles now. The MPG readout is a about 4% optimistic.The second fill-up calculated to 52.4 MPG. While, the MPG readout for the tank was 54.5. I'm pretty sure it was a very accurate measurement, as I filled right to the metal thing down in the filler both times.Stats for the fillup:4.889 Gallons256 milesThe fuel light came on and stayed on at 202 miles. That works out to 3.85 gallons based on 52.4 MPG.If the fuel tank and fuel pump inlet at the same as my 2013 V7R, then usable fuel to empty should be about 5.1 gallons, so, I cut it real close (had an MSR fuel bottle with me just in case).So, that gives me about 1.2 gallons of reserve, or about 60 miles.I can safely look at my current MPG readout for the tank and use that as the number of miles I can go after the low fuel light turns on.
Nice! I'm jealous. Where were youz guys?
Thanks for the review. I really want a V7 III but can't see myself parting with the Cafe Classic and not sure if I want to part with my Yamaha FZ07 for one. I compare the Cafe Classic to all the YouTube reviews of the new Miata. A lot of fun at speeds that won't get you a ticket. The furthest I have ridden the Cafe Classic from home is the 80 miles to Sloans to have the fuel tank recall performed. Other than that I have never ventured further than about a 30 mile radius of home and just enjoy all the little curvy back roads where I live.
So, a month changes perspective I guess. Traded both the classic cafe and the FZ07 in for the V7iii carbon.
I think you're gonna have to update the pic in your signature!
So, just an update from me too. The III now has just shy of 1,200 miles on it and is breaking in nicely.Now that I'm past the 1,500km (930mile) service and letting it rev freely. The hemi-head motor definitely wakes up above 4,500-5,000 RPM. As Kev said, it is a nice evolution of the earlier V7. To further comment on ABS and traction control, I recently got caught out in the '13 V7R and had the back end kick out making a left turn. No crash or anything like that, but, definitely a pucker moment as I had my brain in raid mode and was being gentle with the throttle. The TC would've definitely prevented that. And last week, I had a car make an opposing left turn dangerously close to me. The rear ABS kicked on as I had the front brake on HARD, and apparently didn't easy up on the rear brake enough as the weight transferred forward. The III slowed hard and straight with no drama.While I was a little luke-warm in my initial review, mainly because I was so happy with my previous V7, I'm really loving the III. It is definitely a very nice evolution, and the blue & orange is just beautiful! I can't help but turn and look at it as I walk away.
Are you still in TC 2? I put mine in 1 at 700 miles and like it better. I have never felt a pulse and herd a quick chirp when I had to hammer the front at about 55 the other day. Fyi dropping the forks 10,mm gets rid of the hunting of the Pirelli and improves the feel a bunch on the 3. Simple to change back if you don't like it.
I haven't had the TC kick in yet. You'll not in my post, it was my 2013 that I had the back end kick out on in the rain.
Yes but I made your TC kick in on that tar snake (or we assume it did, unless it was just me reducing throttle and riding out the minor slide that saved it).So, where is your TC set?
Is that most or least intrusive?(Sorry haven't looked into the settings yet)
I purchased my V7III in late May. Quickly ran up to the 1000mi service, re-torque heads, reset valve clearance and changed over to 20w50 synthetic and synthetic gear oil with moly lube in the differential as well.
Pulling the fork tubes up quickens the steering. That and TC-1 is a serious, overly exciting and semi -dangerous choice for me. I'm trying to make a come back from riding light weight sport & race bikes. My spine and depleting strength have arrested the development I envisioned. Thank you for the suggestions. R3~
The final drive oil doesn't need to be changed at the initial service. Like the 2013+ V7 and V7II, it gets changed every 12k miles (20k km). The transmission oil gets changed at the initial service, and then not again until every 36k miles (60k km).
Various roads he likes up in North Central PA, turned around in Shamokin just below Centralia.
