...way less fun than big sweepers...
After 1000's of miles in the Alps for years the one thing that I would recommend is to look thru the turn to where you want to go. (that will require you to turn your head a bit more than you are probably used to.)To truly enjoy the hair pin turn this a must do.:-)
I'm with you, Bill. There are more fun ways to get around a corner.Stelvio Pass is an example of true multiple zero-radius hairpin turns. On RH turns, if you were to turn your bars full-lock to the right and just idle around the turn, you will end up in the opposing lane when you're done. Don't do that. Yes; if you were to increase your speed and add a bit of lean, you'd be able to turn sharper (but, if you were that person you wouldn't be asking the question). But, the general technique is to crank your head around and check for traffic coming, and then (if clear) swing out into the opposing lane and smoothly circle around the turn, ending up fully in your own lane. If you ever end up completing the turn in the wrong lane, you've done it wrong. Going down, you'll be riding the rear brake; going up, you'll be fanning the clutch.It's not uncommon to see BMW GS riders with their feet dabbing the ground as they get turned around. If they lean the bike over in the turn, they can do it easily enough, but when full upright, there's just not enough turning radius for the beast. It might be embarrassing for them, but that's better than dropping a heavy GS in the turn to the cheers of those up top watching. Frankly, I find Stelvio Pass about like doing figure-eights in my garage. The view is spectacular, which is why we love it.
watch for is tour busses, that rear grows longer as he turns. Ha!
Keep your head up and look ahead as far up the road as you can.Keep the gears low and the revs up,and the bike will follow where you see.Once you get the feel for it, get a rhythm and gain confidence.
