Huh ? Dusty
I forgot about you flat-landers. On the handlebars. Push with left hand when making a right hand turn. Push with your right hand when making a left turn. Want a quicker turn? Lean into and fall in the turn. While doing this and pull with the hand for the that turn. Right hand turn. Push with your left, pull with your right hand. For a left, push with your right hand and pull with your left hand on the bars. Way quicker than just leaning.Weight shifting should be done with the head straight up and most of the lean from the waist down. Push with your feet on the pegs for that side of the turn.Practice in a parking lot then try it on the road w/your twisties.
He said that the steering was slow with the 18" wheel. I dispute that and maybe the technique is not there.
My 87 LeMans came to me with an 18" front. 130x80 rear, 110x80 front. It came to me with the stock aluminum fender mount with a fork brace mounted above it. Real ugly, and it had been that way since about 1990. I removed the stock mount and got the fender to mount to the brace. With the 100x90 front tire, it wanted to rub the front of the fender at speed. There was enough space at the bottom side of the fender I was able to 'adjust' its mounting to bring the rear in, which tilted the front up. There's no width issue at all, the height was the only issue.
Wayne;a timely thread for me !getting close to replacing the 16" front on my Mark IV - currently it's a BT45 120/80, which I think is too wide, and was going to change to a 110 / 90. The Bridgestone is showing some feathering now too. Which tyres in that size do you like - BT 45, Sports Demon, Conti, Avon or something else? I'm running a Pilot Activ on the rear, which I like, but can't get that in a suitable size for the front.thanksBazil
