you can often make your own intake manifold rubber by cutting up what is called in the industry as "gas tank filler neck hose". Its fuel safe, it has internal stiffening, and cuts well. Doesn't have the sexy ribs cast in to lock the carb or manifold in place, but is fully up to the task. Just find the stuff with the right ID. Gates makes a ton of it. Get the smooth, not ribbed versions.
