I posted a link to a stock sump last weekend and on page 2 of this thread, buy it now of $29.95
Early 850t models didn't have an oil filter, latter models did.
http://r.ebay.com/gqaYOPSo by getting this sump I'll gain an oil filter? Or my engine doesn't have all the internal plumbing and it will just be a pan with a bunch of extra stuff in it?
Since yours had a Bub sump on it, that means it is late enough to be oil filter equipped from the factory and has the required passages and front main bearing. If it wasn't an oil filter engine to begin with, then the Bub sump wouldn't have been on there.
Swoosh, I have a spacer that I would turn loose of for $50. I might have a sump pan as well. I would have to dig thru my pile. Regardless, you should come to our campout in Bruceport, Wa the weekend of August 13,14,15.Bill Lovelady IS EskimoSpy
Bill is throwing you a lifeline. Take it. Besides what better excuse than "I have to go to this forest to make a buy."
If you get a shallow pan, a spacer might be a good idea, and Bill's got the kit -- one stop shopping, even if you have to party to get it. The deepness keeps the oil farther away from the crankshaft. This helps crankcase pressure/venting/overflow/misting issues that we saw with shallow pans. Later pans are deeper and don't have the issue as much. That's why I suggested it earlier.
The spacer is Guzzi manna, pick it up and give Bill some karma points. An engine tear down might be in order before spending big $$$ on parts. It'd be good to know where you're starting from. If your crank is gone (chrome kills) you've jumped feet first into a money pit.
Don't ask me how I know....
Would've an oil filter saved your engine?
I have rebuilt four non-filter / chrome cylinder engines, all needed a crank re-grind and main bearings. The one oil filter / chrome cylinder engine I have rebuilt did not need a crank regrind or new main bearings.
Loooks like you'll have fun with it. Do have other Guzzis?
Those are good looking turn signals.
I have to break in a new V7 Racer for an Alaska buddy so I will be on it this weekend.
If it has chrome cylinders and it's been ridden regularly, they may still be OK. It's when the bike sits too long that the chrome starts to flake off. No filter, change the motor oil every 1,500 miles.
