Finally, Ohlins S36PL shocks for your �09-current V7 I & II (All models). No damping adjustment options � nor can they be had with them. Order and we will be in touch for your weight details.
Give a call to my boss, Jim Hamlin at Hamlin Cycles, (203) 942-2232. He has been working with the team at Ohlins USA for decades. They build shocks for him to his specifications frequently (he got into a dust-up with the Motus guys because he got a custom shock made for a Motus that transformed its ride to a true sport bike and told them that they ought to try it) and he has a formula worked out for the V7 series. Just be very clear that you are looking for a more plush ride to protect your spine, since most of the people who come to us for V7 suspension work are go-fast guys. We also have other options less expensive than Ohlins that we should be able to get made for your needs that will be less racer-harsh than the Bitubos.
Jay, Hamlins is probably the way to go, but let me add one thing. You've recently ridden Harleys with primitive stock suspensions that didn't hurt your back and handled well, so it's not the presence or lack of adjustable rebound/compression damping that is necessarily going to make the difference.Just saying.
Before ya can make an adjustment to rebound and dampening ya gotta have something to adjust. I've had shocks that were not adjustable but were custom built(springs and valves) for my needs and they worked very well. Paul
I'm puzzled by the point of the first sentence. But the second is basically supporting my original point.I'll go further and point out the majority of the bikes on the road don't have damping adjustments, just preload and sure that likely means they're no perfect for an amateur road racer, but they work fine for most people. I don't know that Jay's needs are much more demanding other than from a comfort standpoint, but even there I suspect he'll be fine with a quality shock that's set-up for his weight/application.
If you only ride smooth roads and aren't too aggressive in the corners you can get away with non adjustable shocks. If the shocks are set up for bumpy roads then they will be too soft when you get into the curves and you will find the bike wallowing.
Give a call to my boss, Jim Hamlin at Hamlin Cycles, (203) 942-2232. He has been working with the team at Ohlins USA for .....We also have other options less expensive than Ohlins that we should be able to get made for your needs that will be less racer-harsh than the Bitubos.
My wife feels her Icons from MG offer a big improvement from the stock torture rack on her V7.
Nope, I completely reject this as subjective dribble. [emoji6]No seriously, there are too many absolutes there for that to possibly be "true".
You have the freedom to do that. I will not spend money on shocks that I can't tailor for the ride. Might as well just run the OEM shocks and deal with the compromises. That is my opinion.
