Not the same, but an option. https://www.mgcycle.com/index.php?main_page=product_info&products_id=373-AJ
I think It's the same p/n as the loop frames:: 55 43 65 25. You could probably make one pretty easily. I think the big challenge would be to find the rubber grommet that fits into the wire loop.
I believe that all of the Ambassadors or Eldorado's had the all rubber guide that requires fender drilling (not 100% sure on that). Rubber grommets come in many many sizes so I don't think that would be a problem. I don't think I'd be very good at making a wire one, especially since I don't have an original to pattern it from.
The front brake cable/hose holder on V7 Sports was welded to the fender braces, not a separate item.
I you just want functionality, couple of zip ties work a treat!!!
These two looms on my bike are actually each bolted to fender. It’s a simple piece of stainless wire with a small loop on one end for fender bolt and a larger loop on the other end for the brake cable. Not very complicated. This loom is sandwiched between the rear brace and fender on each side. They can appear to be welded to the brace but are not. Maybe earlier bikes had welded looms on brace, but my 73 doesn’t.
Thanks, that's sort of what I thought based on photos. I'm gonna order a couple of these, and I bet they will look and work just like the OEM.
Those look pretty close and can probably be easily tweaked into a different orientation if needed. They don’t appear to be a special, complicated or proprietary design.Glad to share pics of mine if it will help..
Yes, please do! Thx
So did the $2.95 parts work after all?
Glad I could help.
