you can also make your own plastic glue by taking some similar plastic and putting it in a glass bottle with MEK overnight. if it dissolves or at least starts to, it'll work. some experimentation is needed to get the consistency to your liking. If you can get it to dissolve it will be very strong, the key is to get a solvent that attacks the plastic. sometimes I use that with plastic welding. sometimes you can make a patch with aluminum pieces bolted to the back of the cover. in all of it some skill is needed to make it invisible or at least look good if you cant hide it.
