Author Topic: Dellortos on an 1100  (Read 669 times)
Offline wirespokes
« on: March 15, 2024, 12:34:37 AM »
Those of you who converted from FI to 40mm Dells - what jets worked best for you? What sort of mileage could I expect on the road? I like going fast, but am not into drag-race starts or slowing/braking in turns.
Offline kfz
Re: Dellortos on an 1100
« Reply #1 on: March 15, 2024, 03:41:42 AM »
Sporti or Cali?
My LM1000 is running is running 145's i think,  so Id start at around 150 and work your way down.   Are you going to try to keep/adapt the airbox?
It would probably be pretty good, assuming you set up carefully. I can easily get 50 MPG (Imperial) if I ride restrained, and the sporti is a more efficient engine.
Kev
Offline wirespokes
« Reply #2 on: March 15, 2024, 05:41:03 PM »
This is a 1999 California 1100 fuel injected. I'll be making it over more like a 78 LeMans or 1000S.
As a Cali with the windshield, it's nice in the winter, but I find it's just no fun. I get no feeling of speed or sportiness. I guess that's good since I should take it easy in the winter - but...
And I'm not particularly fond of fuel injection and all the expensive junk it takes to make it work. Plus it doesn't get very good mileage - ok by the specs, but I know it can do better.  The simplicity of the earlier bikes is what I want. So there you have it - my reasons for mounting carbs. Just today I ordered a Tommaselli Daytona throttle from MG cycle - collecting parts for the eventual makeover. I've already got carbs.
Not sure about the airhox. We'll see how it works out.
« Reply #3 on: March 15, 2024, 06:15:00 PM »
Look up the specs for a 94-95 cali w/carbs, they had a kit with 266 adomizers, I used 268
Offline wirespokes
« Reply #4 on: March 16, 2024, 12:03:04 PM »
Thanks, Steve! I'll do that.
Offline ccoli
  • What? Me Worry?
« Reply #5 on: March 16, 2024, 10:45:12 PM »
36 or 40mm carbs? I run a 98 Cali engine in my Spiii with 36mm carbs.
Don't know what Jets are in there as I don't have that info where I am right now.
How about ignition? I run the stock Spiii Digiplex but had to also use the flywheel to match.
Wisconsin MGNOC Rep
03 EVT/EML hack, 99 Bassa, SPIII, 3-78 Robins, 75 T3, 74 Eldo, 32 Sport15, Ambo custom.
Offline wirespokes
« Reply #6 on: March 18, 2024, 04:09:08 PM »
I've got some 40mm Dells, so why not? I see no reason 36s wouldn't work also.
Ignition? I don't know yet. You mentioned changing the flywheel - hadn't planned on doing that much, but mine has only the TDC marked and nothing else. I'll need to change that - either mark it myself or swap flywheels.
Online Turin
    • crap and stuff
« Reply #7 on: March 19, 2024, 02:57:32 PM »
I would think either carb would be fine on an 1100 med valve motor.
Personally, I'm a fan of a hot Cali.
1985 Sidlow Guzzi
1996 Triumph Daytona 1200
1996 Triumph Daytona 900
Offline lazlokovacs
« Reply #8 on: March 19, 2024, 07:06:59 PM »
I did exactly this with PHM40s (except my 1100 cali motor is double plugged) will look up my jetting when I'm back in UK.
Best running guzzi I've ever had
What ignition curve are you running?
Offline wirespokes
« Reply #9 on: March 19, 2024, 07:26:57 PM »
I haven't done anything with it yet - no mods to the ignition or fuel. I took the throttle bodies apart, adjusted them, and that's it. I haven't looked into what's involved with the ignition yet. Any advice or suggestions? I'll start saving up for it.
Right now I'm focusing on the floorboard to pegs conversion, and then some low bars. One step at a time.
