I'll get some better pictures up.
Those plastic caged bearings are a weak spot too.
Have no fear to go into the transmission with Old Jock's tutorial in hand. How's that for promotion?
Big thanks to everyone for their input. I've just ordered an m10 fine bolt that hopefully will get the old clutch apart and I'm not going to buy anything till I see what's in there. But I do have one final question for now - the clutch alignment tool seems to be £68 ($85) over here. If I bought a complete clutch kit with the new clutch hub boss , could I use that as an alignment tool with the help of a bolt and some washers ?
Just wanted to post this picture for a second opinion. The bell housing on the gearbox side is a bit wet , not soaked in oil but a thin film and within that film a red powder . Not sure if the red is rust or clutch. I'm guessing it's all supposed to run dry , would you say this thin film is normal enough?
Ok , so I got the whole GBX out this morning and took it up to my trusted old fashioned bike mechanic. He had a quick look at the clutch boss with a view to removing it using just elbow grease and said it felt like it would break his homemade castle socket before it shifted. It was his opinion that the front bearing and seal seemed fine.
on one of them the friction material is a little loose , I can rotate it 2 or 3mm.
so my question is can that be replaced from this side ?
