Apologies if this is well-known by others -- I tried to read the manual on this but I couldn't get much information....What type of oil does the V85 gearbox use -- and roughly how much? I just had my dealer perform a service on the bike which reportedly included (among other things) a replacement of the oil in BOTH the engine crankcase as well as the gearbox. I was charged for 1 gallon of 10-60W Maxima Synthetic oil.......does that sound about right? One gallon of oil for both the engine and gearbox?Thanks for any clarification.
Elvisboy,First of all, thank you very much for going to such detail in responding to my questions. I am finding myself increasingly puzzled about a couple of things:I ALSO have a 2020 V85 TT, but it seems that I may have a different version of the manual than you......which is really odd! For clarification, my manual is this very small black book, written in a couple of languages, and I have to use a magnifying glass to read some sections. Page 133 of my version of the manual, for example, discusses fueling (only).I DO note the following stated on page 193 of my version of the manual: "For gearbox oil removal, checking, and replacement, please contact an official Moto Guzzi dealership." I am now wondering if MG modified their manual in an effort to steer folks away from doing their own maintenance?I was aware that the changing of gearbox oil was occurring early; the dealership talked me into the idea of changing the engine oil, gearbox oil, and rear-drive oil all at the same time as an extra-good thing for the break-in. I am fine with that idea, but I am not so fine if they used the improper type of oil for that gearbox. My receipt is pretty clear about the one gallon of 10-60W, and I do not see anything else listed for use in the gearbox (they DO list a specific oil used for the hypoid gear.) Something is not making sense.I am starting to get a not-so-warm-and-fuzzy feeling about all of this. I think I may just get all new oil and swap out everything myself.Thanks again for the information.
Since the motor oil is a lot less thick than gear oil I would just make sure they used the right stuff (ASK THEM!) and ride it like you stole it.
Everyone,This thread probably needs to close-out. I want to offer my sincere thanks --once again -- to all of you for your detailed replies.I had an in-depth discussion with the servicing department. They pointed out that the "hypoid" gear oil charged to me was for a quantity of 1 liter, and that the 1 liter amount was adequate to refill both the gearbox and the [rear wheel] final drive. From what I can tell, it indeed seems to be appropriate to use the same oil (75-140W, I believe) for those two chambers, and that 1 liter would have been enough. I was looking on the receipt for a third oil charge -- not knowing that two different oils were sufficient to change three chambers on the bike (engine, gearbox, final drive).Several things about the oil checking/changing on this bike seem increasingly challenging to me (to add, MY version of the User's Manual does not provide much of any information regarding gearbox oil -- unlike other versions of the same manual). That being the case, however, I really do like the idea of getting fresh oil in all the major mechanical chambers where metal things rub against other metals things. I am inclined to accept that the service department knows what they are doing, made the right recommendations, and did the right things. Moving forward, I would like to slowly learn how to do some of the work on this bike myself, but that will take time. I'm going to consider this resolved for now. Thanks again for all of the support.
Gear oil and motor oil are graded differently. For example, the viscosity of 90 gear oil is roughly equivalent to a 40/50 grade motor oil
Perhaps, but pour both out and you will see that one is thicker than the other, or more viscous if you like
