Stripped, really, the the bolt thread, or the in hex of the screw head?
Sorry I should have clarified, yes the hex of the screw head is stripped and I can't get a hex key in to turn it.Kind of important for timing work, point gap etc..
Use the rear wheel with bike in highest gear to bump the engine into correct position to set rockers and points.It's a lot better than abusing the bolt on the rotor.
Yes you are probably right, and I have done so. Still would be nice to get the bloody thing out.
Just try some sharp jawed vise grips first.Don't hurry to drill this one out because once the cap falls clear you are blocking the rotor extraction threads with the reduced body diameter of the screw you just beheaded.A flat filed either side of the cap would allow fitment of an adjustable wrench. That screw should be 14 ft/lb maximum tension.
Uhh, memory may have failed me again, but isn't that screw head down in a counterbore? If so, I don't see how you could do any of that stuff..
Chuck you amaze me ! Taking pictures and posting them with clear instructions is more time consuming, hard work than the original job.
Yup, another senior moment for me. Been 2 years since I've needed to look at the rotor.Bolt head is hidden. Sorry for the falso hope.
That's why I do it. Guys like Charlie, Pete, Steve, Joe, etc. don't really have time to document all that stuff. Many times, it *does* take more time to document it than to do it, but it's my way of paying back WG for all the things I've learned here.Thanks, John, I appreciate that.
You'll get it out - and without buggering everything up, I'm sure. You're only removing it because it's stripped - correct? You're not pulling the rotor.Just to be sure you know - there are instructions on the net on how to remove the rotor using a bolt and a short section of rod. I've tried that method and it wasn't successful, though it seems like it should work. I've actually heard of that method jamming the rod in the crankshaft which turned into a nightmare. Not worth taking the chance. Just get the proper tool meant for the job - it only costs ten bucks.
I think if you put it in 4 or 5 gear it's easier to turn the engine if I remember correctly. The bolt definitely cuts to the chase a lot faster and seems more accurate when trying to find "the spot", but at the expense of sweating it a little and fingers crossed type exercise that you don't break or strip the bolt.
