ON SALE right now for $279, reasonable amount to fix issue in front end.
….now that the springs are softer.
This was the bit I didn’t get…
If you cut a straight rate spring into two halves, each part will have a rate double that of the original spring.
??? Springs are rated in force/unit length (of compression), like lbs/in. Nowhere in that equation does free length come into play, so HOW does a spring cut in two get stiffer than the original rating?
What isn't mentioned, and one of my concerns: Coil bind in the shortened spring. What determines fork stroke in our Guzzi forks, and how do you determine if the shortened spring won't bind up before full stroke?
My rear shock has been "done", and I like the idea of the Matris fork kit but I really want to research just what my current fork spring rate/length is and see if I can find some springs and do a fluid upgrade. Might swing by Hamlin to see if I can talk to them about it.
