Hi, folks.I'm not an expert on this topic in any way, but having researched many sources when rebuilding engines in the past, I recall that the recommended balance factor for our engines was indicated to be 52% (could possibly have been 51% -- it's been a while). When I had the 949cc engine in my 850-T balanced, I discussed this at length with the balancing specialist (balancing is all they do), and this made perfect sense to them. This engine is using 88mm Gilardonis.The reason I looked into balancing is that the engine in my '74 Eldo police bike has 88mm iron liners and Venolia pistons. While it runs very well, it doesn't seem particularly smooth. I assume that the pistons are heavier than stock, and I was interested to see how much difference balancing would make. Unfortunately, the T engine has not yet run, so I don't have my answer yet. I could possibly dig up the information I found on this subject, if anyone is interested. Cheers,Shaun
My V700 crank was balanced to 52%, rods matched and balanced end-to-end, pistons were already matching. One thing to remember when balancing a Guzzi crank is to add weight for the oil volume in the sludge trap. http://thisoldtractor.com/moto_guzzi_loopframe_crankshaft_balance.html
So..do you think it's runs smoother than a engine as it was done at the factory? V8 engines ,not flat cranks, are balanced at 50%...Generally, a balance factor is often chosen that makes vibration least noticeable to the rider..
