Author Topic: Help please on an electriclal connector  (Read 303 times)
Offline Gliderjohn
« on: May 23, 2023, 09:13:47 PM »
Need to remove the fairing on the T-3 which entails disconnecting the turn signal wires. Do these kind of connectors pull apart?
East Mountains, NM
Re: Help please on an electriclal connector
« Reply #1 on: May 23, 2023, 11:05:20 PM »
I’m not familiar with those , looks like it’s heat shrink covering. Look for a thin parting line and if there isn’t I take a razor and cut one. It looks like I can see one in the pic.
Online pehayes
« Reply #2 on: May 23, 2023, 11:11:40 PM »
Not original.  Someone else's bodge repair.  Covered in 'heat shrink'.  You will have to cut away the heat shrink.  After that, it looks to me like male/female spade connectors under the heat shrink.  Those will pull apart after the heat shrink is gone.  The spade connectors will work but there are better options for removable wiring.
