Author Topic: 2020 v7 iii tune bin vs 2017  (Read 651 times)
Online xackley
« on: August 04, 2022, 12:54:37 PM »
I would like to check out if there is any difference in the late III  tune compared to my 2017 V7.
Is there someone willing to send me a link to their saved oem bin file or PM me for my email address?
Or if  you know they are the same, let me know it is  a waste of time.
Thank you
Don
1958 R69 BMW, 1972 R75/5, 1980 yamaha XS650, 1982 GL1100, 2003 EV, 2007 Triumph America and 2017 V7!!!
All on the road, going nowhere in particular.
Offline usedtobefast
Re: 2020 v7 iii tune bin vs 2017
« Reply #1 on: August 05, 2022, 10:37:37 AM »
Thank you
Don
I was happy enough with my 2017's running that I didn't really feel the need for a remap.  I then put on some an Agostini exhausts and decided to get the appropriate Beatle map at that time ... and it did run better than stock.
As for a newer Moto Guzzi approved/delivered map, wouldn't your Moto Guzzi dealer know?  And I assume if you took the bike in for them to load the new map they would charge you something for that?
Beatle also has a "stock" exhaust map for the V7 iii bikes.
So personally, I would either leave it alone or spend $100 on a Beatle map.
2017 V7 iii Racer
2017 Griso
2016 Stornello
2000 Red Quota
Offline moto-uno
« Reply #2 on: August 08, 2022, 05:27:48 PM »
  ^  "Beetle"   :thumb: . Peter
Online xackley
« Reply #3 on: August 08, 2022, 10:48:44 PM »
Which map did you find appropriate for the Agostini? From reading post about Agostini on a v7, it appears most riders think that the oem tune works, with no need for an update.
« Last Edit: August 08, 2022, 10:53:49 PM by xackley »
« Reply #4 on: August 09, 2022, 09:55:00 PM »
Sure, you can bolt on the Agostini's and ride ride ride and not worry about it.  The bike was not running horrid or anything.  I sent a msg to Beatle at that time and he had an improved map so I just decided to go with that.
Theoretically, with the better map, it will run cooler and smoother, and vibrate less.  I noticed the smoother & less vibration, and it seemed to rev up faster ... but don't really know about running cooler.  For me, $100 to have the bike run better was worth it.
2017 V7 iii Racer
2017 Griso
2016 Stornello
2000 Red Quota
Online xackley
« Reply #5 on: August 09, 2022, 10:24:52 PM »
Actually found that Chrisfer's map works very well.
That map can be found near the end of thread "V7 III map - Guzzidiag - Tunerpro"
I was not sure what his objectives were in his project. What I found is he tamed low end throttle and reduced idle thereby improving slow navigation. About 70 miles on his tune today and it performed when mooping along the lake fronts or winding it out through the curves in the hills or cruising the state highway.
Don
