Get a Beetle map installed for better mileage, unless you know the maping. OR get it tuned better. My EV gets just under 50.
I've done that. The older ECU not supporting the 02 sensor just can't get any better than mid 30s.
Ok, let's clarify: over the last two years, I have loaded several maps, including Beetle maps, I've reset TPS, gone through whole system, I've done it all. The ECU is the problem. It's several generations older than what should be on it, doesn't support the LAMBDA, and the bikes with those ECUs never got much better than mid 30s, anyways. So I don't need advice about how to pull more mileage out of it with the current ECU. I've tried it all.
What I'm trying to find out is if I can load a Calvin Beetle map (for a 15RC.C8 ECU) onto a 15RC.CA ECU.
The ECU isn't the problem, and you haven't tried it all. The 15M can be made give better mileage than mid 30's. Simply adding an ECU that supports Lambda won't make any difference if you're using a Beetle map, because Lambda would be disabled. The actual map is what needs modifying.Also, you didn't answer my question about CO trim.Yes.
As far as CO trim, I'd have to look. Can't remember off the top of my head. Sorry, though. To clarify further, it's not even a 15M.
