Author Topic: Jetting SP III  (Read 1004 times)
Offline dxhall
Jetting SP III
« on: January 05, 2019, 04:10:37 PM »
This bike has PHF 36 Dellortos now with K27 needle in the middle groove, 130 main jet, and 48 idle jet.  It came from Alabama, so probably close to sea level.  The plugs show it was too rich there.  Here in Denver it will be worse.  Any suggestion on what I should change?  If someone has a good setup, I could avoid a lot of trial and error tuning.
Offline yogidozer
Re: Jetting SP III
« Reply #1 on: January 05, 2019, 04:13:43 PM »
I would drop the needle a notch, and see what that does for you. Try new plugs, or clean the ones you have now really well.
Re: Jetting SP III
« Reply #2 on: January 05, 2019, 04:17:18 PM »
Before you do anything else pop the top off a carb and lift the slide out and see if they have a shroud around the atmospheric side of the atomiser orifice. This makes a huge difference to the required jetting.
Offline dxhall
Re: Jetting SP III
« Reply #3 on: January 05, 2019, 04:36:49 PM »
There’s a shroud 360d around the atomizer.  It sticks up about 3mm into the carb throat.
Re: Jetting SP III
Re: Jetting SP III
« Reply #4 on: January 05, 2019, 07:23:28 PM »
Some good stuff right here--- For your area stock pipes, stock set up
http://www.thisoldtractor.com/dellorto.html
On the PHF's alot has to do w/throttle hand, the more you twist the more it squirts
Mine was set up to go, had the headpipes off my LM3 on it, x-over, Lafraconi open exhausts. Mallosi air filters
Pete's going to tell you bout lean burn PHF's
I would make sure it has the smaller stock atomizer in it not 268's but 262's and AB's not AR's
If you keep the K27 needle, 264 atomizer would be almost correct. I always lived close to sea level, though. The size of the pump jet will make it look rich also.
« Last Edit: January 05, 2019, 07:53:56 PM by guzzisteve »
