Morning John, the graph you are looking for is in the V750 Sport/850T manual but it's small. There is another in the G5/SP1000 manual also small somewhat. The one I used w/doing MyECU from AU on my 98EV is the electronic ignition graph in the supplement for SP3 and is large, covers the whole page. It also will be 2-3* initial advance(fixed) which works better for the 1100. I tried the 8* setting and couldn't get the bike to idle correctly w/fueling. The stock mapping goes up to 46* and I had constant pinging, mine stops at 34* and now gets 50mpg. Still a tad lean checking the plugs. I had an O2 sensor to tell me the CO% rate but never got around to using it. Good Luck
Edit: SP3 also uses 36mm PHF's
