Sounds like a nice ride. Don't let Tex bother you he's just jealous. As far as prep for the ride goes the bike shouldn't need anything i particular. If this is your first air cooled bike then it's your first guzzi as well. The speedometer is likely to be way optimistic check it against a GPS device so you in know how fast you're really going. The full mark on the dipstick may be above where the engine wants to run. I worried myself to death topping off with half pint of oil after a day ride once the level got about half a guard below full it stopped and stays there for thousands of miles. Others will jump in on this you'll likely get more advice than you need about everything
Maybe I should elaborate on my post where I said “this happens frequently” as far as “breakdowns”. I wasn’t in no way referring to any issues with your particular bike, just in general such as flat tires, minor accidents or other common issues that can occur with any motorcycle, leaving one stranded while out on the road. 👍
The plan is to work during the day and then hit the road by about 2pm to run for around 5-600 miles per day.
Also, any way to get up to ~900 miles on the bike before the trip, do the first service, then take then trip? And I'd rather do the first service a wee bit early than a lot later. So even 750 - 800 miles and do first service.
What year is your bike? I noticed on the 2021s they moved the O2 sensor up closer to the exhaust outlet than it was on the 2020s. If the sensors were heat soaked from the temps and sun, while the engine was comparatively cold, the fueling mixture might have been off a little bit maybe. ???
the only thing I'd bring is a set of tubes. Patches don't always stick and finding a tube in BFE won't be easy.
when fully loaded, and especially in a head or cross wind, my computer shows very low, such as 35 to 42 mpg. However, when I get to the pump, it still gets about 50 mpg. I try to ignore the computer on a trip but it is hard not to get nervous.
