I recently purchased a 2017 V7 with 30k km (18.5k Miles) It's all stock (except the fuel filter) and was impeccably maintained by the PO and I'm enjoying the bike very much. Having said that, I do have a few comments / questions and wonder if any of them could be solved with an updated map, maybe from Beetle / GuzziDiag?
- The throttle feels snatchy, and a bit sensitive to inputs, even at cruising speed. This is not helped by the poor front suspension, that chatters the bars, and makes holding the throttle in position a bit tricky. (plus slow speed herky jerky happens as well if I'm not super careful on the throttle.)
- The engine vibes pretty good between 90-105 KMPH while in top gear. I can shift around it, but sometimes I don't want to work so hard.
- If I get a bit lazy through the shift, the engine braking really draws the engine down, then there is a jerk when throttling back up. I can finesse this mostly out, but sometimes when I'm tired, I'm less precise.
- the midrange grunt seems a bit more peaky and narrow than I imagined. Like it's too lean for too long, then good, then lean again at the top. But maybe it's all in my head or I'm describing this incorrectly?
I do adore the lazy CV carb on my DR650 (now that I've got it sorted) so going between a CV carb and FI is not helping the experience. The longer I stay away from my DR, the better the FI feels on the V7. But I do love the V7 and hope to get it all sorted out. I think the bike is certainly worth the effort.
I wonder if there has been a map developed that's "better" than the factory 2017 map?
Thanks!
