Your dash light needs to be working to "excite" the charging system. No light. No charge.
Then how was it on with one regulator and not the other? How does this correlate? I have more bulbs so an easy test!!
Did it stop working with the new regulator? The bulb would be the weak link. Yes that's exactly what happens!! The bulb is ONLY out with the new regulator.
I'd quadruple check the wiring. Sit back, take a look, take a break, take another look, repeat.Here is a chart that may help. It's very simplified and doesn't show things such as grounds and bypasses all harness connectors and such, but it should help clarify I hope.
Groover, as helpful as I found your diagram in the past, it is in conflict at the 61 and D+ post versus Bender's website:http://www.thisoldtractor.com/moto_guzzi_tonti_wiring_harness_install_rectifier_-diode_board-_connections.html
Ok....you all had me going so I just went back to my shed. With the new regulator in, the bulb is out. When I put the old one back in, the light is on! Not a bad bulb. The new one gives me more voltage but not enough. So we've eliminated the bulb issue. I'm leaning to something fried in my new regulator. Thoughts???
Maybe those two terminals are interchangeable, not sure. I wish I could remember whom gave me this hand sketch I'm posting now when I first started messing around with my G5 in 2014. It was someone from here, but I was new here and don't remember whom sent it to me and I can't find any emails or PM, so it may have been text... anyway, based on this granular diagram, it appears those two spades could be merged or swapped??Hopefully something (Kiwi Roy ) can chime in to clarify.
That looks like some of my chicken scratching
So Roy, I've not done all that testing yet, but I have exactly zero volts coming out of the 3 yellows on the alternator with all running. The rectifier wires are all correctly placed. I pulled the covers and battery out to check that. The stator shows no open circuits and the rotor tests 3.4 ohms. Is there a test just for the rectifier? I'm beginning to think that between the front and back of the bike, I just plain have an open circuit from a bad wire someplace.
I think, Roy, you're verifying my suspicions with the ground....... It's really the only thing left. I'm going to follow Grover's advice and use a jump wire.
Do yourself a favour and check out one of these. Best bucks I ever spent on my T3. https://www.euromotoelectrics.com/product-p/edl450-altkit105.htm
