Author Topic: V7 oil filter location  (Read 8188 times)
Offline kenvil1
« on: March 17, 2016, 02:30:04 PM »
Hey, where's the oil filter located on a V7?
Pardon my lack of basic knowledge on the matter, but I was just reading about someone dropping the sump cover on a big block to change the filter. Is this the case with the small block as well? I was convinced that routine maintenance on the small Guzzi was a completely painless affair.
Re: V7 oil filter location
« Reply #1 on: March 17, 2016, 02:36:00 PM »
Like an airhead it uses a cartridge filter that is accessed/replaced through a small (1 through bolt retained) cover in the sump.
If memory serves at the front right corner of said sump.
Online Perazzimx14
« Reply #2 on: March 17, 2016, 02:36:46 PM »
On the big block V7" there was no oil filter just drain and refill. The filtered motors did not come along until around 1973. All small block V7's have oil filters. There is a plate on the bottom of the sum where you remove one bolt and the oil filter cartridge will drop right out.
Interesting thing about the filter less motors is they run just as long or longer than oil filtered motors.
« Last Edit: March 17, 2016, 02:39:24 PM by Perazzimx14 »
2017 Road Glide Special
2020 Kawasaki KLX300SM
2016 Suzuki Van Van 200
Offline kenvil1
« Reply #3 on: March 17, 2016, 02:59:17 PM »
Good to know, thanks guys.
« Reply #4 on: March 17, 2016, 04:29:04 PM »
The cover is on the bottom right of the sump. It is finned, and blends in well.  It's got an O-ring, and mine tends to stick. Gently prying will drop it out.  DON'T OVER TIGHTEN it.  They're prone to breaking with too much torque on that one bolt.
Offline davedel44
« Reply #5 on: March 17, 2016, 04:31:34 PM »
Always good to ask when you're unsure.  Much better than screwing something up.  Don't ask how I know. :wink:
Dave
Galveston
Bambino- 2013 V7 Stone
Offline M0T0Geezer
    • The Ones I Rode
« Reply #6 on: March 17, 2016, 04:46:12 PM »
Here's a good diagram on the oil drain & filter on the 750cc small block motors for you:
http://www.dansher.com/bikepix/Guzzi/OilChange.jpg
There is also a fine wire mesh oil "filter" way up inside the engine bottom end.  Have to pull the sump clear down to get to it and it only needs cleaning during overhaul anyway.  Just fyi.
'Geezer
Wisdom from the road:
« Reply #7 on: March 17, 2016, 05:33:40 PM »
Fwiw, I'm pretty sure Ken doesn't have one, he was just curious.
« Reply #8 on: October 05, 2019, 05:06:06 PM »
On the same note what do you guys pay for a V7 filter in US$?
I paid just over CaD$25 which is US$18.78  I thought that seemed steep.
« Last Edit: October 05, 2019, 05:09:56 PM by Kiwi_Roy »
Half a V9 Roamer
Offline stonelover
« Reply #9 on: October 05, 2019, 07:47:32 PM »
Mailorder-$12.00 to $13.00USD  Plus shipping.
Offline M0T0Geezer
    • The Ones I Rode
« Reply #10 on: October 06, 2019, 12:58:29 PM »
From a real old-timer and For What It's Worth, there is a comprehensive on-line Guzzi 750cc reference file here:
  https://www.dansher.com/bikepix/Guzzi/_V7_fyi.txt
I rarely maintain the file any more 'cuz I sold my reliant Breva 750 a while back.  :violent1:
If anyone wants to take over maintenance and hosting of that file, send me a PM.
'Geezer
Offline malik
« Reply #11 on: October 06, 2019, 02:50:38 PM »
Seems excessive to me. Over here they used to be $AUD22 individually, till I found I could buy in bulk at $15. But the Aussie dollar has taken a nose dive in recent months - hate to think what they are now. I have noticed that even on various overseas suppliers' sites, they have never been particularly cheap.
Unlike the Carberry Enfield which was designed to use the Mazda/Subaru spin on filter (Enfielders are generally even more parsimonious than  guzzisti) - easily available everywhere for $AUD6-7.
