...when actually the radius was slightly decreasing...
Those bloomin' decreasing radius turns!
That's what the guy at the wrecker place said! He was well aware of the turn. I didn't think it too bad. It was just blind and I was not prepared for the unexpected. It happens often, to many of us. We usually get away with it. Not this time!
Several mentions that ABS might have reduced the risk. Interesting, and who knows if that is accurate? I would say likely given my one ABS intervention event on the Triumph. The curve/bridge/truck timing/lighting was a clear cascade risk event. Hate those combinations. Heal up.
I only mention ABS as an alternative but of all the bikes I have owned and ridden the EV was the most prone to front wheel lockup. I attributed it to a soft springing up front that would bottom out under hard braking and also the rear brake pedal being hard to use in a panic situation. Most of the time flat footed on the floor board you have to lift your foot then try to modulate the pedal. So you are stuck with the hand brake and having to pull hard to compensate for lack of rear brake. EVs are fine for putting around and otherwise do well in sport mode if you in the zone and paying attention. Not so good when the unexpected happens. I have locked the brakes on other bikes but only gone down on the EV.
Geez, Marty. Thank Goodness you're ok. The bike tells a story that you're current condition betrays. So glad that half helmet did it's job. I too love them, Really enjoy the air. After my recent get off, though, I took this picture in the ambulance....Everywhere there's damage....my half helmet wouldn't have helped. reason for pause.Best of luck while you tie up all the loose ends regarding the mishap.
