Tank propped up and finally found the coils. Which are painfully obvious when you know what to look for and where too look for it. Thanks to everyone for your patience. Wires now removed and off to the dealer for the new contacts.FWIW: I have one on each side of the bike, along the upper frame.Some pics of my adventure (it was adventurous to me)Tank propsCoils! SuccessWell and truly friedOne part away from up n running
That's why I run the wires through plastic tubing, right there. Glad you found it. You realize that you've now successfully mechaniked, right?
Yes, congrats on the mechaniking - you are now officially dangerous.[rodekyll], what is your recommended source of plastic tubing? My homebrew equipment ? Garden hose ?
I go to the hardware store and buy a few feet of bulk, clear plastic tubing. The limp stuff, like your aquarium hose. If you have 8mm plug wires, get 3/8 tubing. Screw a screw into the end of the wire and attach a length of that soft "baling wire" you can get in the hardware store. I use wire from my welder. Get the tubing hot (heat gun or boil it) until really soft and then use the little wire to pull the 8mm wire through. If you're quick and lucky you can get it all arranged on the bike before it cools. Then it will set-up better along your chosen path.
The yellow beast is grumbling like a kitten. Which is as it ought to be. The salvaged terminal/connector to the coil appears to be working just fine. The dealer was nice enough to strip n crimp it for me while I was picking up the longer wires. Timmy, you were spot on about the rubber pucks. Loose, both of 'em. They're now tightened.I'm still taking it into the dealer: decided I didn't want to deal with the clutch cable, they can do a compression check at that time, and give my fixes a once-over. Having said that, it felt really good to get this little bit of mechanic work under my belt. Thanks to all for your tips and advice.I'm going to (loosely) zip tie up the clutch cable tomorrow morning, take the bike for a short ride to get it up to temp, and change the oil & filter. And that should be that.
So he left a stolen Honda IN YOUR DRIVEWAY when he traded up?
