Damn it, Chuck! You guys stole my idea I've been on the lookout for a cheap (free is nice too) wall oven for the shop also.Mostly for the install of bearings. Never thought of powder coating with one.For the bearings the wife says "use the kitchen oven, you've done it before". Well, it wasn't winter then and I could open the windows and doors.More info on this DIY powder coating option please.
I've never had issues with bearings. I store bearings in the beer fridge's freezer so they are ready to go when I am. When it comes time to use them I hit the interference part with a heat gun for a few minutes. Pull the bearing from the wrapper quickly coat with a thin film of grease and normally it drops in. Sometimes a few light taps on the bearing driver are needed to get it home. Never had to resort to the oven for bearing work.
So how are you removing the bearing to be replaced? I used a heat gun or placing whatever on the woodstove up until I got the oven, both work... eventually. The oven is just easier and faster. I do chill the bearings too, but that alone doesn't always do the job.
Hi Chuck,I'm currently building a powder coat oven out of an old kitchen stove I got from my mom when they were rebuilding the kitchen, it has been standing around for years now. Finally got to start the project in december.
I grounded it to an eight foot solid ground rod just outside.
The electrical motor repair shop at work replaces 1,000's of bearings per year. I'll have to inquire about their means and methods for how they do on and industrial scale. I don't think they have a beer fridge/freezer
Everything in the panel box goes to an isolated ground bar rather than combining with the neutrals. I have all my ground cables going through the wall rather than the cold water pipes. They attached to two eight foot ground bars four feet apart. Is that overkill as well?
Easy to determine, is your panel or service entrance separately grounded to a rod in the ground(earth). If it is, no worries. Wire your oven outlet as per usual, two hots a neutral and a ground. If not, drive a rod into the earth and connect that to an earthing strip in the shop i.e. your metal frame building. Paul B
I drove a separate ground bar for powder coating. It works well.
In some older systems neutral and ground were synonymous, in todays world a separate ground is required by code and if your panel didn't have it ,it would be necessary to put one in to be up to code. You say it's there, your conduit would act as your ground as long as it's metal. As long as your powder machine is properly wired I don't see the need for a separate ground in your case. PaulB
They, most likely use an induction bearing heater.
